Ever pull a gas pedal wiring harness and TAC module?
My 5.3 LS engine donor was a low mileage '08 Tahoe. I bought the motor, wiring harness and gas pedal from an acquaintance who had it pulled and then decided to go with a 6.0 that came along. (he works in the auto insurance industry and sees all the good stuff that comes along) I got a gas pedal but he told me he never got the harness and TAC module. My local wrecker has an '08 truck. The other day I was there and didn't have much time but took a look. I followed the wire from the pedal up and left to WAY up under the dash. There was a short branch to the brake switch. I couldn't find where it came through the firewall when I looked under the hood nor could I see a little box. I've since been told the module is supposed to be behind the battery. I need to go out there and give it another try. Has anyone ever removed a gas pedal wiring harness from an '08? Should I grab the brake switch? Any idea where it comes through the firewall?
Re: Ever pull a gas pedal wiring harness and TAC module?
An '08 engine is a GenIV, they dont have TAC modules. Just get the pedal and as much of the wiring as possible and you will have to splice it into the engine harness.
My '72 short bed build. http://www.ls1tech.com/forums/conver...6-0-4l80e.html 5.3 swap into my RUSTY '71 C10 http://ls1tech.com/forums/conversion...71-c-10-a.html |
#3 | |
What about the brake switch? Does the PCM need a signal from the brake? I read somewhere there's a 12v feed from the pedal that is normally on, and off when the brake is applied - the opposite of a regular brake switch. |
The ECM does need a 12v signal from the brake switch, but only when the brakes are applied, so your existing switch should work. What you read about needing 12v with the brakes not applied is for the older GenIII engines.
Thanks ls1! Some great info.
