Old 12-17-2018, 09:01 PM   #1
Tripmiester
Tripmiester's Avatar
1970 Quadrajet 7040509 600cfm
Have a nice 600 cfm Quadrajet from 1970 California only manual transmission
$125 shipped
Came off a running truck 10 years ago, probably needs a rebuild it has been in a plastic bag in dry storage.
Tripmiester is offline   Reply With Quote
Old 12-18-2018, 07:38 AM   #2
Tripmiester
Re: 1970 Quadrajet 7040509 600cfm
ttt
Old 12-19-2018, 07:28 AM   #3
Tripmiester
Bump
Old 12-19-2018, 09:34 AM   #4
I guess I'm ignorant off these. Could you explain what makes this one special? Are 600cfm Q-jets rare or uncommon?
Old 12-31-2018, 09:17 PM   #5
Tripmiester
ttt
Old 01-01-2019, 07:30 AM   #6
Oddfire
Oddfire's Avatar
Quadrajets only came in 3 sizes: 750, 800, & 840. 750s were used exclusively on all Chevrolets. 800s were used on later model Buick Olds Pontiac & Cadillacs. The 840s were a special Hi-Perf breed used only on Pontiac SD 455s for 1 year...1970. The 750s were also put into service on some 6 cyl applications made possible by using smaller Idle tubes & idle down channel & restricting the opening of the secondary airflaps. The 0509 carb you have listed originally came on a 70 truck with a 396 w/ manual trans & destined for Cali. Didn't mean to write a book or cause any problems in this thread but I've been using these carbs for years & thought it necessary to provide this information.
Oddfire is offline   Reply With Quote
Old 01-01-2019, 09:49 AM   #7
Tripmiester
Oddfire,
Thanks for the info, so is this a 600 CFM?
Here is a reference sheet but I don’t see a CFM identification column.
Trip
Old 01-01-2019, 03:03 PM   #8
Oddfire
Oddfire's Avatar
No...the airflow of that carb is 750cfm the factory controlled the metering for various engines by drilling the idle air bleeds, down restrictors and also the main jet/ metering rod combos. No matter what you've heard...there's no such thing as a 600 or 650 qjet. jamie
Old 01-01-2019, 03:14 PM   #9
Oddfire
Oddfire's Avatar
7040509 CHEV 70 TRUCK 396 CALIF 78 49 7036019 BG 2.8926 4.2474
This is right off of Lars sight. The following info is what all these numbers mean:
Carb # Application Main Jet Main Rod Spring Sec. Rod Jet Area Jet Area
This does not however give the cfm ratings...that's just a given
Old 01-01-2019, 03:20 PM   #10
Tripmiester
Oddfire,
Thanks for the expert info!
