Old 12-17-2018, 11:30 PM   #1
dondb
Trailing arm e brake bracket line removal?
I have the whole rear end off the truck and want to replace the trailing arm bushings. Also taking the rear end out to clean and paint. How does the e brake line come out of the bracket on the trailing arm. The cotter pin comes out but the gap is smaller then the brake line fitting? It's a lwb step with rear drum brakes. Thanks for any help
1969 C-10 LWB SS
1969 Camaro Pro Tour
2002 Camaro SS LE Rag Top #937
dondb is offline   Reply With Quote
Old 12-18-2018, 07:40 AM   #2
PGSigns
PGSigns's Avatar
Re: Trailing arm e brake bracket line removal?
Are you talking about the E-brake cables? They get tapped back and the cable will fit through the slot in the bracket. I have seen a couple that over the years the bracket has been closed up a little and I had to take a screw driver and pry them open just a bit.
Jimmy
60 to 66 Chevy and GMC window decals
http://67-72chevytrucks.com/vboard/s...d.php?t=661131
Good friends, good food and a hotrod what else do you need?
1966 BBW long fleet Daily driver
1965 BBW short fleet Sold and going to a good home
1965 Suburban
2003 3500 Duramax
2005 Ultra Classic
PGSigns is offline   Reply With Quote
Old 12-18-2018, 09:23 AM   #3
dondb
Jimmy
Yes to e-brake cable removal from bracket it trailing arm. So i need to disconnect the cable upstream and pull it back to get the cable through the opening Thanks that makes sense since the e-brake connector was to big to pull through.
1969 C-10 LWB SS
