Old 11-21-2003, 12:20 PM   #1
Stout72
Not my good side.
Stout72's Avatar
Question Cyclic vibration?
I'm experiencing a cyclic vibration while driving on the freeway. It occurs at about 65mph (not sure of the speed since my speedo is not calibrated for 35" tires), between 3400 - 3500rpm. I can feel it slightly in my feet thru the floorboards, and it sounds like, "a-rum... a-rum... a-rum." It almost seems to go away when I back off the throttle. Anybody have any ideas what this could be?
72 Chevy K20 Custom Camper, 350/350, 4" lift, dual shock suspension front & rear. Daily driver and a work in progress.
00 Suburban LT
90 Camaro RS
79 Yamaha XS1100 Special (Ol' Reliable)
Stout72 is offline   Reply With Quote
Old 11-21-2003, 12:26 PM   #2
*MJF*
No longer truckless
I would check the easy/cheap things first. Change the ujoints. Maybe have a shop change them for you so they can check the balance of your driveshaft as well.
We will need a little more info on your truck though. Is it lifted? How do the angles of your driveshaft look? Are they correct for your type d-shaft( CV style or standard two ujoint style)?
*MJF* is offline   Reply With Quote
Old 11-21-2003, 12:49 PM   #3
Hotrod70C10
Low & Slow
Hotrod70C10's Avatar
Sounds like mine before I replaced the u-joints and carrier bearing. If it hasn't done it the whole time you've had the truck I would just mark the driveshaft with chalk and take it apart. I replaced my u-joints at home with a small vice and a couple of sockets. If it has been vibrating since you bought the truck I would take it to a shop like *MJF* said.
70' C-10 LWB Fleetside
4.5/6 drop
Hotrod70C10 is offline   Reply With Quote
Old 11-21-2003, 01:05 PM   #4
Stout72
Not my good side.
Stout72's Avatar
The vibration started just recently.
Truck has a 4"lift, one-piece drive shaft w/standard u-joints. The angles appear to be ok, but I've never checked them. I've had this truck for about a year and a half, guess I need to spend some more time underneath. For future reference, what should the angles be?
00 Suburban LT
90 Camaro RS
Old 11-21-2003, 01:14 PM   #5
8.1PWR
8.1PWR's Avatar
I don't know what the angle is supposed to be but if it started after the lift was installed you may have to take the drive shaft to a driveline shop and have double cardan joints put in. That helps get rid of driveline vibrations.
1970 Chev C20, 2wd, LB, 350 4BBL, muncie 4spd, 4:10 limited slip.
2002 Chev 2500HD 8.1L Allison, 4X4.
1996 Chev S10 Blazer, 4X4.
2006 Jeep LJ Rubicon
8.1PWR is offline   Reply With Quote
Old 11-21-2003, 01:20 PM   #6
oldsub86
I would start by making sure the tires are alright. If you know anyone with a similar truck, borrow his wheels and tires for a few minutes and see if you still have the vibration. We did that with my brother in law's truck and basically proved that the wheels and tires were not at fault.
1968 Chevy - 292 with a powerglide
oldsub86 is offline   Reply With Quote
Old 11-21-2003, 07:51 PM   #7
*MJF*
No longer truckless
Here's an explanation about the angles. I'm trying to find a better pic but I can't remember where I saw it.
http://www.4x4wire.com/tech/pinionangle/
Old 11-22-2003, 01:15 PM   #8
Stout72
Not my good side.
Stout72's Avatar
The lift was installed by some previous owner. I can only assume that it was done right back then, but I will check. Tires are new BFG ATKOs mounted back in February, and show no sign of abnormal wear. It's probably a u-joint like you said. Thanks to all.
00 Suburban LT
90 Camaro RS
Old 11-22-2003, 02:04 PM   #9
Martin64
Martin64's Avatar
I'd check the tire pressure and the balance...
Martin Gibson
USAF Retired
1964(-ish) C10
Martin64 is offline   Reply With Quote
