Old 12-18-2018, 07:59 PM   #1
74CustomK20
74CustomK20's Avatar
Question Core support mount help?
Hey everyone, I need some help. My 74 c30 has BAD mounts for the correct support. Sourced some new (to me) ones from a k20. Problem, the new to me ones are from a 81/87. I know the rubber bushings are different, but so are the holes to mount. Does anyone know if it's just the 81-87, or so I need to find some from a 73/80? I'm planning on a 4wd swap this winter, and want to use factory mounting if possible.
Big Nate
Carp. Local 224. Buy made in the USA!
03 F350 6.0 Daily Race Truck.
79 C70 366 Project Dump.
74CustomK20 is offline   Reply With Quote
Old 12-18-2018, 08:42 PM   #2
sweetk30
sweetk30's Avatar
Re: Core support mount help?
73-80 or 81-up is the split for the 2 styles .
and for the most part its the frame that makes the choice for what it needs .
i have used 81-up body's on 73-80 frames with 73-80 mounts no problem .
77-k30lb BIG truck build .
87-k30lb budget beater build .
85-k30lb the plow machine build .
85-c10sb summer fun toy .
HOLLEY SNIPER efi = worst case of p.i.t.a i ever had .
EDELBROCK pro flo 4 = best deal going so far . love my setup works great.
sweetk30 is offline   Reply With Quote
Old 12-18-2018, 10:30 PM   #3
74CustomK20
Hmm, interesting. Measuring the holes is what messes me up. The 74 top holes are 1-1/2" apart, and bottoms are 2" center to center. The 81-87 I have are 1-3/4 top and bottom, which is what's confusing me.
Big Nate
Old 12-18-2018, 10:38 PM   #4
sweetk30
sweetk30's Avatar
unless you post a pic i got no clue what your telling me at this point .
i know the frame bracket hole is way smaller on 73-80 over the 81-up so the 81-up bushings wont drop in them unless you open them up .
Old 12-18-2018, 10:52 PM   #5
USSkoval
The earlier C30's used a different mounting hole pattern for the core support mounts.
-Andy
'77 K5 Blazer
'78 K10 Shortbed
'78 C20 Suburban
'79 K30 Crew Cab Dually
'84 C10 Short Stepside
'88 K20 Suburban
USSkoval is offline   Reply With Quote
Old 12-20-2018, 06:55 AM   #6
74CustomK20
That's what I mean, the 4 bolting points on the side to actually mount it on the frame. I tried to upload pics, says I need a security token? Never needed that before.. but that's my problem USSkoval. If I found some from a 73-80 frame, should be good to go right?
Big Nate
Old 12-20-2018, 08:08 AM   #7
rpmerf
rpmerf's Avatar
https://www.rockauto.com/en/catalog/...body+mount,673
ENERGY SUSPENSION 34103G
It's the full set - radiator, cab front and rear. 73-80. $70.
1970 C20 Custom Camper - 350, TH350
1997 GMC Suburban
1994 Acura Integra GSR
1987 Dodge Daytona Shelby Z
rpmerf is offline   Reply With Quote
Old 12-20-2018, 09:13 AM   #8
74CustomK20
Correct, but I need the frame mount, that rivets on. I am curious if 1/2 and 3/4 is the same as my 1 ton, after finding out 81-87 are different.
Big Nate
Old 12-20-2018, 09:18 AM   #9
74CustomK20
Small update, I found a set of 73-80 1/2 ton 2wd mounts, and they look identical to mine, as in staggered mounting holes. Now if I can confirm that 4wd will be the same (and I don't see why they wouldn't be) I'll be good.
Link to the mounts
https://www.ebay.com/i/273574582933?...d6428fffd53fb5
Big Nate
Old 12-20-2018, 10:23 AM   #10
rpmerf
rpmerf's Avatar
Rock Auto shows that mount kit as fitting C20, C30, K10, K20, and K30 73-80. I know C10s have different rear cab mounts, but I don't know if the core support ones are the same.
1997 GMC Suburban
Old 12-20-2018, 12:12 PM   #11
74CustomK20
Correct, but ny pieces in question are the mount that attaches to the frame, and their mounting spread pattern. I've been thinking of just ordering those 2wd ones...
Big Nate
Old 12-20-2018, 12:36 PM   #12
sweetk30
sweetk30's Avatar
your first round of info didnt specificly say frame mounts that riviot to the frame the body mount sits on .
so 2wd and 4wd have different front mounts on the frame . the lower half has more so the 4wd leaf spring hanger will attach to it .
now if you want to use 4wd on 2wd i dont see why you cant . you will just have some extra stuff is all . but i can not confirm this 100% .
Old 12-20-2018, 06:55 PM   #13
USSkoval
For some reason it says I need a security token too. I'm not sure what that means at all.
I know of a guy on another forum doing a 4wd swap on a '74 crew cab. The '73-'80 B52 mounts he bought to use needed modifications to fit the shape and hole locations on the frame. Which means the stock brackets will not directly bolt up either.
I've got a '78 2wd Burb and a couple 70's K trucks too, I'll do some measuring tomorrow. I'm going to be doing a 4x4 swap on the Burb, so this is info I need to figure out anyway.
-Andy
'77 K5 Blazer
'78 K10 Shortbed
'78 C20 Suburban
'88 K20 Suburban
Old 12-20-2018, 08:43 PM   #14
74CustomK20
Thanks Andy, I've debated on keeping it 2wd but a 4x4 is more practical in my use, plus a lot more desirable in southern Indiana. I know the 2wd brackets are 1-1/2" apart on top and 2" apart on bottom, but I can't see any reason why the 4x4 mounts will be different, know what I mean?
Big Nate
Old 12-21-2018, 08:37 PM   #15
USSkoval
My '78 C30 Burb has the staggered mounting pattern for the core support mounts. Roughly 1.5 across the top, and 2.0 across the bottom.
My '79 K30 has the even spaced mounting pattern for the mounts. Roughly 2.0 across the top and bottom. In daylight, I can confirm it's the same as my '77 K5, but I'm fairly possitive it's the same.
-Andy
'77 K5 Blazer
'78 K10 Shortbed
'78 C20 Suburban
'88 K20 Suburban
Old 12-21-2018, 11:24 PM   #16
74CustomK20
So they are different from. 2wd to 4wd... Figures.
Big Nate
Old 12-21-2018, 11:59 PM   #17
USSkoval
It's nothing a little bit of drilling can't take care of.
-Andy
'77 K5 Blazer
'78 K10 Shortbed
'78 C20 Suburban
'88 K20 Suburban
Old 12-22-2018, 08:57 PM   #18
74CustomK20
True, but which mounts do you go off of? Droll the frame to theounts specs or vice-versa? Guess of you mount the core support up and see where it lands n go from there...
Big Nate
Old 12-22-2018, 09:23 PM   #19
USSkoval
My plan is to mount them up so that they line up to the core support. That should put the two different mounting patterns at a shared center. Then drill/slot to get 4 grade-8 bolts in there with hardended washers and locknuts. Any slop in the holes shouldn't matter because the spring hangers and little support brackets will will have their own set of fresh drilled holes in the frame.
-Andy
'77 K5 Blazer
'78 K10 Shortbed
'78 C20 Suburban
'88 K20 Suburban
