Old 11-21-2003, 02:46 PM   #1
76bonanza
76bonanza's Avatar
door question
What all will I have to replace in order to replace a 1976 door with a 1979 door?
Looks like the window crank and door panel are diff. not sure what else?
thanks
1968 c10
lowered 3" 4"
355/Th400 built by Hatfield racing in joplin MO
76bonanza is offline   Reply With Quote
Old 11-21-2003, 02:56 PM   #2
bigblock73
yeller
bigblock73's Avatar
the window crank shaft is shorter on 73-76 doors as compared to 77+...so you will need to replace/modify that in order for your window crank to fit. Aside from that and what you mentioned...not much else.
The whole window crank shaft deal happened to me when I was too cheap to pay for 73-76 doors for Yeller, so I purchased 77 up doors..what a PIA!
The kicker, the GM 73-76 doors at the time were $225, while the 77 up were under $200...helluva lot cheaper than now!!!!
bigblock73 is offline   Reply With Quote
