Old 11-21-2003, 04:21 PM   #1
J-Spec C10
Whats this wire for?....
J-Spec C10's Avatar
neutral safety / reverse switch
I'd like to get my reverse lights working again, and Im prety sure that its the neutral safety switch. Aparently they go all the time. So my question is this... where do the go? Im almost positive they go on the column, is there any trick to it?
Kyle
CANADIAN CONNECTION
'82 C10 Resto-Custom--> * 2 1/4" manifold back dual exhaust with Hooker Aerochambers & High Flow Cats *Taylor Ignition Wires *Centerline 15" Telstars with 32"x10" mudders
J-Spec C10 is offline   Reply With Quote
Old 11-21-2003, 04:25 PM   #2
bpmcgee
bpmcgee's Avatar
J-Spec,
I don't think the neutral safety switch affects the reverse lights. At least not on my stick shift.
On my stick, I've got a pair of wires -- one green one black, which go to a plug on the trans drivers side near the front. These are the reverse wires.
Brian
bpmcgee is offline   Reply With Quote
Old 11-21-2003, 04:35 PM   #3
Prerunner1982
Prerunner1982's Avatar
if your park/nuetral safety switch goes out.. you wont be able to start your truck.... i dont think if effects the lights...
Jon
1982 Chevy Silverado 350/th350.... RETIRED
1993 Jeep XJ 2 door(Cherokee) 4wd 4.0ltr/AX-15 (5spd)/NP231
Oklahoma Roll Call
Prerunner1982 is offline   Reply With Quote
Old 11-21-2003, 05:15 PM   #4
79BIG10
I'm back with 2nd truck!
79BIG10's Avatar
I would think that it does affect it. When you shift the column the switch moves over. Replace it and see if it helps.
1979 Chevrolet Bonanza Big10 "Tootsie Roll"
1985 Chevrolet Silverado (wife's)
Member of the Southern Bowties Club
"Don't underestimate how sexy a fat man who drinks to excess can be." Homer Simpson
79BIG10 is offline   Reply With Quote
Old 11-21-2003, 05:19 PM   #5
PHOENIX
On a manual truck the the back lights are not affected by the safety switch. The safety switch on a manual is mount above the clutch pedal. The reverse light switch is mounted on the trans. I am not sure what you have, but all this is for manual I have no idea about auto.
* AVOID: LOPER'S PERMORANCE / LOPERSPEED.COM OF PHOENIX, AZ & COTTMAN TRANSMISSION *
PHOENIX is offline   Reply With Quote
Old 11-21-2003, 05:30 PM   #6
J-Spec C10
J-Spec C10's Avatar
I work at an auto parts store. In the manual transmission trucks the switch has a different # and location. In the automatic (which I have) its located on the column somewhere, and our system says its an integrated part. So the neutral safety part still works but the reverse part is no longer functioning. I was just wondering if anyone had replaced one yet? I'm going to have to do it with no repair manual still.
Kyle
CANADIAN CONNECTION
Old 11-21-2003, 05:41 PM   #7
swervin ervin
You get what you pay for
swervin ervin's Avatar
On autos, the neutral, start, and backup light switch is all together in one unit. It's mounted at the base of the steering column.
Mike
1985 Chevy C-10
swervin ervin is offline   Reply With Quote
Old 11-21-2003, 06:08 PM   #8
J-Spec C10
J-Spec C10's Avatar
cool, thx Mike. I already ordered the switch. its only $9 cdn anyways.
Kyle
CANADIAN CONNECTION
Old 11-22-2003, 11:33 PM   #9
Jason Spears
Jason Spears's Avatar
Its the white gizmo on the steering column. You can see it if you look up under the dash. It just clips into the column. I replaced mine when I was putting the tilt column in my truck but I did it when the column was out of the truck. Its pretty easy to drop the column or even pull the column out in our trucks. Good luck.
Jason
Jason Spears is offline   Reply With Quote
