Old 11-21-2003, 06:59 PM   #1
Broken_down?
Chirp. chirp chirp chirp chirp.... faster
Last couple of days I noticed a "Chirping" noise coming from the rear of the truck. when I speed up it chirps faster and when I slow down it chirps slower. rear wheel bearings?? ideas plz.. 68 chevy LB CCS 2wd 350 sb. also I just noticed it today when I kick it in ass to go It feels like the truck is roasting but it is not. I have big ass tires. I would have to major power break to light them up. any ideas on these 2?
Rich
Don't get upset when she marks her territory in the driveway.
WHY DO THEY CALL THEM JUNKYARDS ANYWAY??? I LIKE TO THINK OF IT AS A TREASURE HUNTING MISSION
Broken_down? is offline   Reply With Quote
Old 11-21-2003, 07:50 PM   #2
jhow66
jhow66's Avatar
u-joints!!
56 Chevy Bel-Air 2dr. HT (purchased new)
71 Chevy Cheyenne SWB PU (502HO)
65 GMC short bed step--work in progress and my gofer
jhow66 is offline   Reply With Quote
Old 11-21-2003, 07:53 PM   #3
sactoC10
71 DELUX
sactoC10's Avatar
Not sure what the chirping is, but I drove up to Oroville last week to pick up a GREAT roll pan from one of your neighbors. Small home business, and he had a (69 I think) dragging the frame at the side of his house...and a HUGE engine build up in his garage.
Hope you figure out what the chirping is.
sactoC10 is offline   Reply With Quote
Old 11-21-2003, 08:18 PM   #4
beautimus
beautimus's Avatar
brakes rubbing?
i survived cancer and kidney stones, but my kids are killing me.
beautimus is offline   Reply With Quote
Old 11-21-2003, 08:49 PM   #5
jeffbo
D.U.F. Member
jeffbo's Avatar
Worn bearing in the driveshaft center carrier?
MEMBER OF THE DISCS UP FRONT CLUB
'72 C-10 LWB Highlander, A/C, tilt TH350 w/ B&M shift kit, 327LJ bored .040", cast flattops, forged crank, L31 Vortecs, 9.25:1 CR, Comp conical valvesprings, Crane Energizer single pattern 216/.454", Professional Products Power Plus Crosswind intake, Edelbrock #1406 600cfm, HEI, dual exhaust, open 3.08 12bolt
'68 C-10 4spd (not running)
'79 C-10 LWB Mild 350
'80 Caprice Classic, 2-dr
'97 GMC K-1500, SWB, Reg. Cab, Z-71, 5.7, Auto
jeffbo is offline   Reply With Quote
Old 11-21-2003, 09:42 PM   #6
Broken_down?
now the noise stopped. wtf? I am thinkingthe brakes. if one of the brake pads is over adjusted woudl that make applying the brake harder then normal pull to say the right of left?
rich
Old 11-22-2003, 12:11 AM   #7
Jeff M.
Jeff M.'s Avatar
My vote is for the u-joints too.
69 C-10 CST Short Fleet, Factory Air, BB427-400 Auto-2400 stall-tilt-cruise-Tach & Vac Gagues, 4/6 drop, power one piece side windows, Eaton posi.
Jeff M. is offline   Reply With Quote
Old 11-22-2003, 10:38 AM   #8
jmanz69
Careful, they attack...
jmanz69's Avatar
It might have been the rear brake. You wouldn't notice it pulling from the rear brakes. You might have noticed it locking up one of the wheels in the rain though. Really only notice brake pull on the front wheels unless it's really bad.
jmanz69 is offline   Reply With Quote
Old 11-22-2003, 03:22 PM   #9
71GMC_3/4T
Weapons Of Construction
71GMC_3/4T's Avatar
I'd wonder if you had a part fall off one of your rear brake assemblies. I would pull the drums and have a look at it.
1971 GMC 2500, 402/TH400 4.10 Daily Driver
Lafayette, CO
71GMC_3/4T is offline   Reply With Quote
Old 11-22-2003, 10:14 PM   #10
cableguy0
my carrier bearing made a similar noise to what you are describing and it went away
Owner of North Point Car Care in Dundalk Md. We specialize in custom exhaust on both modern and classic vehicles. We are a full service auto shop from classics to modern vehicles. Feel free to contact me with questions. I will give a 10% discount to any board member.
cableguy0 is offline   Reply With Quote
Old 11-22-2003, 10:25 PM   #11
jorgensensc
jorgensensc's Avatar
I would start with the drive line. It's not too expensive:
Heavy duty (these have grease fittings)U-Joints= 10.00 Need 3
Carrier bearin=15.00
Just make sure you mark everything so the driveshaft stays balanced.
1972 C20 Suburban- Big Blue Betty
'56 Chevy Bel Air Sedan- Frame up Restoration
-What would you attempt to achieve if you knew you could not fail?-
-I Refuse To Tiptoe Through Life, Only To Arrive Safely At Death's Door-
R.I.P. EAST SIDE LOW LIFE
jorgensensc is offline   Reply With Quote
