Tire Width?
I have a 1965 C10 with the body at the painters so I can not measure or evaluate the width of the tires. I am converting over to disc brakes front and rear 5x5 pattern. I have researched and selected american torq II rims 16 x 8 with 4 inch back spacing which according to the research will fit nice. My question and concern is can I install 265 width tires and everything clear the fenders or do I need to go with a narrower tire? I am planning in the future to install 2.5 drop spindles in front and 3 inch drop springs in the back so I want to make sure these tires will still fit.
![]() Join Date: Jan 2011
Re: Tire Width?
I am running 235's on 6 inch wheels in the front and 255's on 8's in the back. The rears will rub the wheel tubs when going in and out of steep driveways but I am at 5" of drop in the back. The rears did not rub with the first set of 255's but the new ones have a wider section width. The tire you choose will have a lot to do with how they fit. With 2 1/2" drop spindles, 2 inch springs the 15X8's on the front would not work with 255 tires, they hit the front fenders.
Jimmy Jimmy
60 to 66 Chevy and GMC window decals http://67-72chevytrucks.com/vboard/s...d.php?t=661131 Good friends, good food and a hotrod what else do you need? 1966 BBW long fleet Daily driver 1965 BBW short fleet Sold and going to a good home 1965 Suburban 2003 3500 Duramax 2005 Ultra Classic |
Re: Tire Width?
PSG
thanks for your reply I think I am only doing a 21/2 drop spindles in the front with the standard springs. The 3 inch drop springs are for the rear. Will that make a difference? |
![]() Join Date: Aug 2014
Re: Tire Width?
My truck has a 5/7" drop and im running 20x9.5 wheels with 285/35R20 bfgs. I did have to roll my fender lips inside but it didnt bother me any.
1965 C10 LS2/4l70, WHITE, 5/7 DROP LINK TO SUPER SNOOPY C10 BUILD---> http://67-72chevytrucks.com/vboard/s...d.php?t=689283 1977 C10 SILVERADO HAWAIIAN BLUE, 5/5" DROP, LS6/4L80E 1976 CHEVY K5, 350/350, YUBA GOLD/SADDLE |
![]() ![]() Join Date: Jul 2002
Re: Tire Width?
265/70x16 are a pretty tall tire. I know they won't clear up front even just with spindle drop. Rear, I think mine would rub the top outer part of wheel well. It's just a big/tall tire if you are going to lower it.
Re: Tire Width?
so what do you think would be the widest tire size that would fit a 16 x 8 rim?
Re: Tire Width?
275 on a 15x8
Re: Tire Width?
For the rear, you are going to have to find something that is 28" tall or shorter. With a 16" wheel, you are looking at a 255/60 or possibly a 295/50. One big factor is do you have a69 & older axle or a 70-72 rear axle. The later axles are 1.5" wider than the original width, which will effect your tires.
For the front I would say a tire 26.5" tall or less. Tires in 16" probably a 235/55 would work. If you can even find the tires in this size, I would suggest the 235/55x16 up front and the 255/60x16 for the rear. Again your rear end may effect that choice for the back.
Re: Tire Width?
sweet thanks guys for all of your help.
