Old 12-20-2018, 11:28 AM   #1
Ozark Tim
Ozark Tim's Avatar
WTB: big block stove pipe
See picture
I need one of these if anyone has one for sale. Heat riser stove pipe between manifold stove and air cleaner
Ozark Tim is offline   Reply With Quote
Old 01-23-2019, 05:06 PM   #2
Ozark Tim
Ozark Tim's Avatar
Re: WTB: big block stove pipe
TTT still looking for this part
Old 01-25-2019, 01:04 PM   #3
Ozark Tim
Ozark Tim's Avatar
ttt
Still looking
Old 01-26-2019, 03:32 AM   #4
Classic Bowties
Always on the hunt...
Originally Posted by Ozark Tim View Post
ttt Still looking
I know that we have some 402 BBC truck heat stove tin and pipe combo's pulled/stored upstairs, can check on availability of the BBC pipe by itself in the morning. Are you needing/hunting for anything else 68-72 big block related? Mel
Classic Bowties is offline   Reply With Quote
Old 01-26-2019, 08:29 AM   #5
Ozark Tim
Ozark Tim's Avatar
Thank you for checking
This is for a 72 c20 I bought out in Utah and the pipe is missing but I think it is complete otherwise. If you have a lot of BB stuff for these ill keep that in mind as I have several of these trucks with the stock 402
Old 01-26-2019, 09:52 AM   #6
Classic Bowties
Okay, I just went and had a look and we only have complete two piece BBC heat stove tin and pipe setups available right now, no single BBC riser pipes by themselves at this time. If you own/have any small block trucks needing the same upper stove pipe, we do have three loose SB riser pipes available/on hand. Would any of your other 402 trucks need the lower BBC manifold mounted tin shield? If you were interested in a BBC stove tin and a riser pipe, I can get you some pictures of the two piece BBC heat stove and pipe setups that we have on hand. Since you mentioned owning several 402 trucks, I have added a link below to one our BBC parts board F/S threads for you to check out. Let me know, Mel
1968-72 BBC parts board F/S thread link here: http://67-72chevytrucks.com/vboard/s...d.php?t=760308
Old 01-26-2019, 11:41 AM   #7
Ozark Tim
Ozark Tim's Avatar
Please send a picture of the tin and pipe
I don't mind buying as a pair since some time I'm sure I'll need a tin down the line
Old 01-26-2019, 09:33 PM   #8
anew4961
i need a complete stove pipe setup also if you have any left
anew4961 is offline   Reply With Quote
Old 01-28-2019, 01:56 PM   #9
Ozark Tim
Ozark Tim's Avatar
Mel
Hey if you can post a picture of a pair you have for sale (tin and pipe) I appreciate it
Old 01-28-2019, 05:35 PM   #10
Classic Bowties
Mel
Sure can, I will take some pics and get them posted up this afternoon. We currently have two 402 BBC heat stove tin and pipe setups pulled, will give you first option on either setup. Mel
Old 01-28-2019, 06:28 PM   #11
Ozark Tim
Ozark Tim's Avatar
Ok great I appreciate it Mel
Old 01-29-2019, 07:38 AM   #12
Classic Bowties
Mel
Hey Tim, got these dug out for pics and posted them in the below linked F/S thread, I gave you first call on either setup. Let me know if you have any other questions, Mel
F/S thread link: http://67-72chevytrucks.com/vboard/s...00#post8453700
Old 01-29-2019, 09:13 AM   #13
Ozark Tim
Ozark Tim's Avatar
Thank you for posting the pictures Mel
I would like set #2
Just PM me the paypal info and I will take care of that tonight when I get home
Thank you for giving me the first at bat on these
Old 01-29-2019, 09:47 AM   #14
Classic Bowties
I would like set #2
Hi Tim, you got it and to keep our F/S thread in order and moving along, please confirm in the actual F/S thread with your I'll take it and which set. Thanks, Mel
Old 01-29-2019, 09:55 AM   #15
Ozark Tim
Ozark Tim's Avatar
Done thanks Mel
Old 04-10-2020, 05:54 PM   #16
chevytom7267
chevytom7267's Avatar
Hello,
I sent you a private message about a big block stone pipe and heat shield . I have a 1970 C-20 CST camper special with a 400 big block that is missing the stove pipe and shield and I'm trying to restore the truck to original. If you or anyone in this thread would happen have one please private message me. Thanks, Tom
chevytom7267 is offline   Reply With Quote
