Old 11-21-2003, 09:12 PM   #1
jugernot
Life, Be In It.....
jugernot's Avatar
Question fan spacer HELP
Can tell me what size fan spacer I should use for a for a small block with a long water pump. I will also use the stock fan shroud. Thanks
jugernot is offline   Reply With Quote
Old 11-21-2003, 09:19 PM   #2
jugernot
Life, Be In It.....
jugernot's Avatar
I forgot I will probably be using a 4 core radiator.
Old 11-21-2003, 10:08 PM   #3
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
Get the rad first, then install the shroud and see what you will need.
It'll be 10 times better if you get a fan clutch.
