12-22-2018, 09:40 AM | #1 |
What 4 speed do I have? 1969 c20
I am doing a ls swap and thinking about using this transmission. Which tranny do I have? Any input would help. My engine is all stock. And looking to get it on the road. I have this c20 4 speed that I belive to be good.
Thanks. |
12-22-2018, 02:54 PM | #2 |
All about them K’s
Re: What 4 speed do I have? 1969 c20
Looks like an sm465 to me.
Tyler '57 3100 http://67-72chevytrucks.com/vboard/s...d.php?t=813888 '72 K20 Cheyenne: 5” lift, 35’s, front dana 60 blah blah blah… http://67-72chevytrucks.com/vboard/s...d.php?t=662879 ‘69 K10 SWB: 4” lift 33”s… in a million pieces http://67-72chevytrucks.com/vboard/s...d.php?t=805206 '98 Silverado LT K2500HD ECLB Vortec 454/4l80E: 6" lift 35x12.5x20’s |
12-22-2018, 03:52 PM | #3 |
Ditto, 465
12-22-2018, 07:41 PM | #4 |
Thanks folks
12-22-2018, 09:14 PM | #5 |
How long has it been sitting like that? The shift tower is open to any rain and snow that chooses to fall on it. Even odds are it will be full of water.
12-23-2018, 10:23 AM | #6 |
It’s all good. No moisture. From what I have gathered this transmission has a extremely low first gear. Does this sound correct?
12-23-2018, 10:24 AM | #7 |
YUP! AKA Granny gear.
Unrestored 68 C-10 CST. Original 327. 4-Speed CH465. 50k or so miles. TREASURER, Drum Brake Club. |
12-23-2018, 08:46 PM | #8 |
What are your goals for the truck? How are you configuring your swap motor? The SM465 is an awesome trans for a working truck. The deep first gear makes offroading and towing possible with moderate gear ratios.
But if you are looking to build a hotrod type street machine, the SM465 is the wrong transmission. I ran a big cammed 327 in my Jimmy and the torque characteristics were completely wrong for the gear split on the 465. With the 210@.050 cam that is in it now, it works great.
12-24-2018, 10:23 AM | #9 |
Granny is 6.55:1. You won't use it unless farming or rock crawling. And that's ok, just something to be aware of.
12-24-2018, 01:40 PM | #10 |
My 4x4 has 3.07 differential gears and 33 inch tires and 1st gear even with that set up is pretty much un-needed on the street. You'll be left with essentially a three-speed. As somebody else mentioned it is a fine transmission for a working truck, I tow a 4,500 pound travel trailer and will use 1st to get things moving.
