Old 12-22-2018, 02:30 PM   #1
Cristiann8
Gas tank vent questions
I have a question about the vents on the gas tank which is the vent And what do I do with the other ones just leave them uncovered? I attached a photo
Cristiann8 is offline   Reply With Quote
Old 12-22-2018, 03:55 PM   #2
B. W.
B. W.'s Avatar
Re: Gas tank vent questions
The pipe on the sender is fuel out (obviously). The two smaller ones, on either side of tank are vents. The larger one (beside the fuel filler) goes up to the top of the fill neck to vent air out (equalize pressure) when fueling.
If running fuel injection with a return you can use one of the vents for a return.
B. W. is offline   Reply With Quote
Old 12-22-2018, 06:27 PM   #3
PepperTreeGarage
PepperTreeGarage's Avatar
I have that same tank. The far single vent is capped off. I didn't need a return line. The larger one of the two goes to the filler neck. Vents air out while filling. On the other one I put an anti-roll vent. This vent is needed for when the engine draws fuel. Lets air into the tank to replace the fuel that is being used. Subsequently, I didn't like the vent being outside my filler box. It is now inside the box out of view. Don't forget a filter. I put mine in the frame rail under the cab where the new hard line from the rear tank meets the old line from the in cab tank. Hope this helps. Good Luck.
PepperTreeGarage is offline   Reply With Quote
