Old 12-22-2018, 06:03 PM   #1
35boulder
35boulder's Avatar
Manual Throttle
Would someone please explain to me why was the manual throttle installed on some of these trucks? What was its purpose? Thanks
35boulder is offline   Reply With Quote
Old 12-22-2018, 06:11 PM   #2
mike1971c10
mike1971c10's Avatar
Re: Manual Throttle
I use mine as a poor man's cruise control
mike
my build thread http://67-72chevytrucks.com/vboard/s...d.php?t=522167 vietnam vet 67-68
mike1971c10 is offline   Reply With Quote
Old 12-22-2018, 08:22 PM   #3
Grumpy old man
Grumpy old man's Avatar
Re: Manual Throttle
^ That's a really bad idea . unlike real cruise control it doesn't shut off when you step on the brakes . Usually found on c-20/c-30/c-50 used to maintain constant low speed for loading along side of tractor in fields , or running higher throttle on PTO equipped trucks . Can be used to increase throttle for morning warm up . Can also be used to temp set throttle higher for steep hill manual clutch engagement ,Makes it easier than using 2 feet on 3 pedals .
1967 Factory short bed - Old school
'71 - 350 / 4bolt / 487 heads / Edelbrock C3BX
Muncie M-22 4 speed / Hurst Comp plus
Factory 12 bolt posi 3.73 / 255-70-15
Smoothed firewall / Factory cowl induction
Power disc brakes / power steering / 3.5-5" drop
Grumpy old man is offline   Reply With Quote
Old 12-22-2018, 09:07 PM   #4
Mike C
Mike C's Avatar
Re: Manual Throttle
Most likely for running PTO driven attacments. Pumps, winches, etc.
44 Willys MB
52 M38A1
64 Corvette Coupe
68 Camaro 'vert LT1 & TH700
69 Z/28 355 12.6's @110
72 Jimmy 4WD 4spd 4" & 35's
02 GMC 2500HD 4x4 Duramax
Old 12-23-2018, 09:20 AM   #5
35boulder
35boulder's Avatar
Re: Manual Throttle
I was wondering if it had something to do with farming and such. Thanks
Old 12-23-2018, 11:02 AM   #6
Grumpy old man
Re: Manual Throttle
Back then they were tools not toys .
Old 12-23-2018, 11:50 AM   #7
too much stuff
Roadtrip!
too much stuff's Avatar
Re: Manual Throttle
I have seen them quite often on blazers and jimmys also.
67 gmc custom lwb dakota truck. Sold...And bought back
69 swb 4x4 project (in progress)
70 c-10 lwb texas truck
70 4x4/BB/bkts/posi/tach(retired)
70 swb (wifes)
70 jimmy camper
71 K-5 factory 2wd
71 cheyenne 4x4/tach/posi/ plow rig
71 Cheyenne20 BB, buckets, tach, tilt, 4 speed
72 jimmy CST wyoming rig
72 jimmy Colorado rig
72 lifted texas 4x4 3/4 ton burb
65 fury conv. 383/auto
65 chrysler 300 "L" 413 auto
too much stuff is offline   Reply With Quote
Old 12-23-2018, 12:34 PM   #8
Keith Seymore
Keith Seymore's Avatar
Re: Manual Throttle
mike
I did, too, on my square. I eventually installed an over the counter cruise control kit, so I removed the manual control (found it in a box the other day).
They have a quick release feature; if you smack it to the left it releases completely without having to dial it back.
Besides - it pretty much has to be long stretches of flat, level, deserted highways for it to be of any benefit. They don't work very well as a cruise control on hilly terrain or in traffic.
K
Chevrolet Flint Assembly
1979-1986
1986 - 2019
Old 12-23-2018, 02:25 PM   #9
chevy71super
Re: Manual Throttle
I was raised on a Montana cattle ranch in the 60's and 70's. When we fed the livestock in the winter we would place the truck in 4 Lo, first gear (granny) pulled the throttle out a couple of clicks and jumped on the back cutting the bale strings to feed. The truck would creep along fairly straight going through the snow, small irrigation ditches and whatever else was in the way. Dad could feed by himself if no one else was around. The local dealer ordered them that way for the ranchers.
71 Cheyenne Super 4X4 SB
72 Cheyenne Super 4X4 SB
72 Cheyenne 4X4 SB
chevy71super is offline   Reply With Quote
