Old 12-23-2018, 11:04 AM   #1
focusedontheprize
focusedontheprize's Avatar
Replacing 20 gallon saddles with 16 gallon saddles
Currently my 1986 C30 has dual 20 gallon saddle tanks. I have found debris and crude in the lines so I will be completely replacing the fuel system in the truck. I have ordered new lines and came across a great deal for 2 brand new 16 gallon saddle tanks.
I know the 16 gallon tanks are shorter and imagine the filler hose will be longer, but is there any other differences I should be aware of?
Thanks.
focusedontheprize is offline   Reply With Quote
Old 12-23-2018, 11:58 AM   #2
sweetk30
sweetk30's Avatar
Re: Replacing 20 gallon saddles with 16 gallon saddles
need longer filler hoses or the factory metal filler hose extensions i have these i just removed from a 16 to 20 swap on a 2 tank truck .
frame holes for the bracket might not be there so you might have to drill them for 1 of the hangers .
otherwise bolt them up and go .
77-k30lb BIG truck build .
87-k30lb budget beater build .
85-k30lb the plow machine build .
85-c10sb summer fun toy .
HOLLEY SNIPER efi = worst case of p.i.t.a i ever had .
EDELBROCK pro flo 4 = best deal going so far . love my setup works great.
sweetk30 is offline   Reply With Quote
Old 12-23-2018, 09:24 PM   #3
focusedontheprize
Thank you sweetk30.
Old 12-28-2018, 10:45 AM   #4
GonicGM
GonicGM's Avatar
I have the 16 gallon tank fill pipes and clamps to under bed crossrails for longbed if you don't buy from sweetk30
83 K30 SRW 350 TH400 NP205 4.10 9' Fisher
85 K30 SRW 350 TH400 NP205 4.10
87 V3500 Dually 454 TBI SM465 NP205 4.10 9' Fisher
83 K2500 350 TH700R4 8600GVW Dual Tank 4.10
1973 Cheyenne Super 30 DRW Std Cab Z83 4.10
1976 Silverado C30 Std Cab 4.10 DRW (4 sale)
GonicGM is offline   Reply With Quote
Old 12-29-2018, 10:27 PM   #5
focusedontheprize
Thank you GonicGM. I am waiting for my fuel lines before jumping in so I will keep that in mind.
