Old 12-23-2018, 12:17 PM   #1
CG
BlahBlahBlah
Blazer roof for a truck canopy?
I was just looking over in the blazer section and was wondering if anyone has ever taken a hosed blazer top and rebuilt it as a short box truck canopy? I'm assuming its the same width as a truck since the tailgates are interchangeable. I think it could be a nice look.
Old 12-23-2018, 06:09 PM   #2
B. W.
B. W.'s Avatar
Re: Blazer roof for a truck canopy?
I think you would need two to section together to make it long enough. IMO it would look good.
B. W. is offline   Reply With Quote
Old 12-23-2018, 06:22 PM   #3
CG
BlahBlahBlah
Oh, I assumed that the box sides on a short box and a blazer were the same length. Definitely would take some work on the side that was close to the cab =)
Old 12-23-2018, 06:47 PM   #4
El Dorado Jim
blazers are shorter than a shortbed pickup
El Dorado Jim is offline   Reply With Quote
Old 12-23-2018, 06:53 PM   #5
CG
BlahBlahBlah
Guess you can tell Ive never owned a Blazer =)
Probably a non starter then. I imagine they aren't giving blazer tops away anymore =)
Old 12-23-2018, 06:55 PM   #6
hugger6933
Here is some more food for thought, there is a Blazer half cab[or least there was] that would be nice for a roadster type truck. as an aside I rebuilt a Dodge Daktoka Sport that was a convertible. In fact [I found paper work shortly after the re build that led me to think it was model number one] it was a very fun truck though underpowered, but then werent most of them
hugger6933 is offline   Reply With Quote
Old 12-23-2018, 09:36 PM   #7
Boog
laying low
Boog's Avatar
I have seen a number of fiberglass canopies that really do look a lot like a blazer top. I bet a google search would come up with some really good choices.
Boog
69 Chevy stepside, 358/T350, 4.11 posi, 4.5/4 drop, rallys, poboy driver
primer is finer
91 Chevy sportside, Tahoe, Yukon & GMC Crewcab All GM..'nuff said.
Old 12-24-2018, 04:34 AM   #8
'68OrangeSunshine
'68OrangeSunshine's Avatar
Yup. My '71 Jimmy has a wheelbase of 104''. My '68 Stepside has a 112'' WB.
Old 12-24-2018, 01:45 PM   #9
CG
BlahBlahBlah
It isn't anything I'm looking at doing. I often see stuff on the board that has nothing to do with what I'm up to. But I find all of our truck stuff interesting and often come up with questions for curiosities (my) sake.
Old 12-24-2018, 02:05 PM   #10
jocko
jocko's Avatar
yep, can make your blazer look like a pickup-ish, but not the other way around
Old 12-24-2018, 02:47 PM   #11
'68OrangeSunshine
To answer your original question, Yes, and I have seen it done. I remember seeing a shortbed fleetside ['69 - '72~] that had a K/5 looking doublewalled top. It had been 'stretched' with an extension section grafted in, making the cap come up to the rear window. The cab-over door window roof section was removed. The stock parallogram side windows were more forward, and in the widened back section, they had stuck in one of those van-style porthole windows. That might date the mod to the Late '70s, Early '80s, when junkyards were full of cheap '67-'72 trucks and parts, and vans ruled the asphalt all the way to the drive-in.
I never met the owner, and the sighting was maybe 20 years ago. The fibreglas work was well done, you could not make out where the seams were.
It would be prohibitively expensive today. Last year I saw a double wall Blazer top at a Tucson junkyard for sale. They wanted $500 for it, and it had no rear hatch. When I cruised by again, a few months later, the price -- spraypainted on the side window -- had been altered to read $599.
And you need two. Then there's the rear hatch.
Brothers makes a duplicate Blazer hatch -- sans any hardware or gaskets -- only $699.99. I bought one about 19 years ago for my Jimmy. Not the best fit. Rattles something fierce.
An interesting pipe dream, but not very practical.
Old 12-24-2018, 02:53 PM   #12
'68OrangeSunshine
I used to call those "Trazers". [Does sound better than ''Bluck".]
Old 12-24-2018, 04:32 PM   #13
jocko
jocko's Avatar
here's another not-so-common marriage of the two breeds...
Old 12-25-2018, 11:00 AM   #14
Mike C
Mike C's Avatar
Shortbed truck is 115" wheelbase.
44 Willys MB
52 M38A1
64 Corvette Coupe
68 Camaro 'vert LT1 & TH700
69 Z/28 355 12.6's @110
72 Jimmy 4WD 4spd 4" & 35's
02 GMC 2500HD 4x4 Duramax
Old 12-25-2018, 12:17 PM   #15
ho70
ho70's Avatar
this is on our craigslist finds page....https://spokane.craigslist.org/cto/d...772726207.html
ho70 is offline   Reply With Quote
Old 12-25-2018, 04:03 PM   #16
'68OrangeSunshine
You are correct, Sir.
It was late at night and I didn't feel like going outside with a tape measure.
