Front Bolt on Roll Pan ?
Anyone Make A Front Bolt On Roll Pan For a 69 c10 instead of a bumper
Posted via Mobile Device |
Re: Front Bolt on Roll Pan ?
I could be wrong but I don't think they make a bolt on kit. I know to make them right you have to cut the frame horns off the front of the frame. To me cutting the frame is not worth the roll pan.
68 c10 swb stepper 68 c10 swb stepper 67 c10 lwb 06 gmc duramax |
#3 | |
![]() Join Date: Jan 2016
https://www.ebay.com/itm/FOR-1967-19...Ombk:rk:1:pf:0 You do have to cut the frame horns and make some simple brackets to screw it to the fenders. Mine sits between the radiator support and the deflector, took some effort to make it all work. It is as "bolt on" as any other aftermarket part that claims to be bolt on. ![]()
1967 C10 Step side 1970 AMX 390 1977 Datsun 280Z highly modified with '95 LT1 power |
laying low
![]() Join Date: Mar 2001
Steel front and rear roll pans used to be available from several vendors as well as fiberglass I think. I've considered putting them on my 69 stepside. If I do I will fab up a heavy bar to bolt in between the frame horns to give some additional strength behind the pans.
And of course save the horn cut offs for a time when the bumper might be going back on.
Boog 69 Chevy stepside, 358/T350, 4.11 posi, 4.5/4 drop, rallys, poboy driver primer is finer 91 Chevy sportside, Tahoe, Yukon & GMC Crewcab All GM..'nuff said. I stand for the flag and kneel at the cross |
