Motor Mounts & Perches
Hey y'all, just a quick question, may be a dumb one but oh well.
I got a set of the CPP 6372-MP (https://www.summitracing.com/parts/clp-6372mp-sm) for Christmas. And planned on buying the Dirty Dingo motor mount sliders. My question is about rubber, is the CPP suppose to come with rubber to go in between the mount and perches? Or am I srong in that the dirty dingo is just an adaptor and then you use like a stock motor mount and then it sits on the perch? The CPP talks about switching to 59' to 70 passenger car And dirty dingo says if truck mount it may need to trimmed. (https://www.dirtydingo.com/shop/mobi...pID=9&CDpath=3) Will '59 to '70 passenger car mount fit with the dirty dingo? Thanks Last edited by bbluma; 12-24-2018 at 09:29 PM. |
60-66 Nut
![]() ![]() Join Date: Mar 2007
Re: Motor Mounts & Perches
You will need the '59-'70 car engine mounts recommended by CPP, which will bolt to the DD sliders. The DD sliders are just adjustable adapter plates that allow you to use any typical small block engine mount to install your LS engine.
