Old 12-25-2018, 10:50 AM   #1
Redraider
donor engine choices
Hi guys,
I have tried to search this but can't get the search wording to get me what I need. Which is...........in reading here about putting an LS in my 51, what would be the best donor as far as oil pan/front accessory drive? Or does everyone get the engine they want and then swap in what is needed? Seems the correct choice to start would be simpler and cheaper, but I have no clue on how this is supposed to work!
I guess I need guidance on what the actual requirements areas far as oil pan and anything else that is a swap problem.
Anyway any help you can provide would be greatly appreciated.
Redraider
Redraider is offline   Reply With Quote
Old 12-25-2018, 11:30 AM   #2
Clyde65
1965 Chevy C10, 2005 4.8L/4l60
Clyde65's Avatar
Re: donor engine choices
I found this...
Try searching for 47-53 and LS swap, OT LS swap in AD trucks
http://67-72chevytrucks.com/vboard/s...d.php?t=541636
Clyde65
Rebuild of Clyde
http://67-72chevytrucks.com/vboard/s...84#post8338184
69 Aristocrat Lo Liner build
http://67-72chevytrucks.com/vboard/s...84#post7561684
support our troops!
Clyde65 is offline   Reply With Quote
Old 12-25-2018, 11:51 AM   #3
mongocanfly
Post Whore
mongocanfly's Avatar
Lots of LS swaps into the AD trucks...
Most people start with a truck engine and go from there...mkat truck engine setups are the same..
Acc drives are a issue with some people using the Holley drive setup..
oil pans will depend alot on what else your using and how low your riding ...you'll have to clear the axles/crossmember....and the ground ...one of the shallowest pans you can get is for the c6 vett.....
Best thing is get a engine and go from there..modify or swap whatever becomes a issue
Mongo...aka Greg
RIP Dad
RIP Jesse
2023 Chevy Z71..daily driver
