Old 12-25-2018, 04:00 PM   #1
KQQL IT
At the body shop.
KQQL IT's Avatar
Heater core died.
Flushed the cooling system. And... the heater core gave up the next day.
Searching thru threads not finding one with many pics for an A/C truck.
Looks like a real pita
Not to mention the 2nd heater core in as many weeks.
Links would be appreciated.
Ordered this for a replacement.
APDI 9010121
Not really concerned if its aluminum or brass.
Pics show it either way.
" That didnt make it any newer "
" Dont antique the equipment "
KQQL IT is offline   Reply With Quote
Old 12-25-2018, 04:19 PM   #2
projectking
projectking's Avatar
Re: Heater core died.
Split open or just plugged? If plugged hit the outlet with the garden hose and push the slop out
68 GMC C3500 Longhorn DRW
67 Chevy C10 LWB
90 Mustang Gt
90 Mustang Notchback
projectking is offline   Reply With Quote
Old 12-25-2018, 04:55 PM   #3
KQQL IT
At the body shop.
KQQL IT's Avatar
It split.
Never really worked to well until the flush then worked better than ever til it split the bed. Ha-
Old 12-25-2018, 04:56 PM   #4
kazoocruiser
Since the core is split, that is a drag. Cost me $300.00 for someone to do the R&R job for me. I was happy to fund someone else's labor for that chore.
And if you DO have to R&R it, the inner fender well pretty much has to be dropped out of the way. Don't forget to wear really good eye-protection.
kazoocruiser is offline   Reply With Quote
Old 12-25-2018, 05:18 PM   #5
pwdcougar
pwdcougar's Avatar
Even on a non AC truck it is a pain. Last time I did the job the inner fender and the hood hinge had to come off. I’ve never understood why a part lik this is made to be so difficult to replace. On my 05 Impala it was. $1300 job. I told people the was they build cars is to set the heater core in a jig and then construct the vehicle around it!
Paul
"You know that little thing in your head that keeps you from saying things you shouldn't? Yeah well, I don't have one of those"
1969 Mercury Cougar Standard 4 speed
1969 Mercury Cougar XR7 convertible
1970 4WD Chevrolet Suburban
1997 4WD Chevrolet Silverado Extended Cab Short Bed (purchased new January 1997)
pwdcougar is offline   Reply With Quote
Old 12-25-2018, 05:40 PM   #6
KQQL IT
At the body shop.
KQQL IT's Avatar
My 98 was super easy comparatively to this.
About 10 screws 2 heater hoses. The oem spring clamps where the worst part of it.
Sounds like a fun job. ��
Old 12-26-2018, 12:45 AM   #7
toolboxchev
Inner fenderwell, Black heater box, and repeat.
Take the tire off first of course. Easiest way I ever found.
toolboxchev is offline   Reply With Quote
Old 12-26-2018, 01:14 AM   #8
Stocker
20' Daredevil (Ret)
Stocker's Avatar
Not much help, I know.... more than 20 years ago, pre-forum, I replaced the heater core in my A/C K20. It was quite quite a pita as I recall, but I did it and hope I never need to do it again. I'm just a general maintenance with basic hand tools in the carport guy, so it can be done by just about anyone with determination. But it's no fun.
FWIW, I have heard of problems with aluminum heater cores, and brass is preferred. No specific info though, just a memory of something I saw somewhere.
- Mike -
1972 K20 LWB 350/350/205
RIP El Jay
Stocker is offline   Reply With Quote
Old 12-26-2018, 02:13 AM   #9
FirstOwner69
FirstOwner69's Avatar
Try this link. It should help. Ignore post 3.
http://67-72chevytrucks.com/vboard/s...d.php?t=223703
FirstOwner69 is offline   Reply With Quote
Old 12-26-2018, 03:19 AM   #10
KQQL IT
At the body shop.
KQQL IT's Avatar
Thanks. That's more what I was looking for. Also now recalling this truck had the A/C added with all the factory stuff.
Really beginning to dread this particular project.
Old 12-26-2018, 08:17 AM   #11
I replaced a heater core and not long after I was doing something else under the hood and put pressure on a heater hose causing the poor solder joint in the new core to leak. Had to go through everything all over again to fix it. It was a Modine brass many years ago.
Old 12-26-2018, 11:01 AM   #12
davepl
davepl's Avatar
Just FYI, all the replacements I found were GARBAGE compared to how heavy duty and strong the original Harrison unit I found in there was. I have a feeling I'm going to regret not just getting the original rebuilt! But I hung onto the core...
1970 GMC Sierra Grande Custom Camper - Built, not Bought
1969 Pontiac 2+2 427/390 4-speed Coupe
1969 Pontiac 2+2 427/390 4-speed Convertible
davepl is offline   Reply With Quote
Old 12-26-2018, 06:22 PM   #13
cypressbog
Go Pack Go!
The one on my truck sprung a leak so I bypassed the heater because removing 50 year old rusted bolts didn't sound like a chore worth trying.
cypressbog is offline   Reply With Quote
Old 12-26-2018, 10:23 PM   #14
KQQL IT
At the body shop.
KQQL IT's Avatar
Already did that.
Sad part is it didnt really work til I flushed the system. Then it worked pretty decent til the water works started. Almost 4 hours, stupid old trucks. Ha-
Old 12-26-2018, 10:32 PM   #15
projectking
Originally Posted by KQQL IT View Post
It split.
Bummer! Better off finding a good original as the aftermarket aren’t very good.
67 Chevy C10 LWB
90 Mustang Gt
Old 01-12-2019, 12:05 AM   #16
Whamp48
Advance auto parts sells a good brass heater core, same size as original. Costs around $35.
Whamp48 is offline   Reply With Quote
Old 01-12-2019, 11:04 AM   #17
HO455
HO455's Avatar
Do you know if they stock the Deluxe heater core?
RIP Bob Parks.
Old 01-13-2019, 02:03 AM   #18
Already Gone
70+ ( Old Skool Club )
Already Gone's Avatar
I'm going to have my heater core rebuilt. Its not that I'm having any problems with it but my original radiator seeps a bit and I'm going to get it rebuilt. I am figuring once the rad is done the weak link in the system will be the original core so I've actually decided i'm going to get the heater core done first as it'll be the tough one to R & R as my truck has Factory A/C.
1992 K1500 GMC Suburban
" In the end, we only regret the chances we didnt take "
" Time is the only currency we spend without knowing the balance, use it wisely ." ..
Already Gone is online now   Reply With Quote
Old 01-13-2019, 08:34 AM   #19
Usually with radiators and heater cores it's age that gets them. So, good thinking on that move.
Old 01-13-2019, 09:13 AM   #20
Boog
laying low
Boog's Avatar
My first old truck had a persistent radiator leak. I tried numerous times to solder it myself but I never could master the art of soldering. Anyway I thought a good cooling system flush might be good for the old truck. It was a '56 by the way. I didn't skimp on the flush. I bought a Dupont flush as it was the best on the shelf at the time. It's a 2 part deal. I followed directions and it cleaned it up real nice. Inside the rad tank it looked like new. Feeling good about it I refilled the system with new a/f and thought, job done. Thumbs up!
The next day the water pump went out. It was super clean inside but the flush had finished off the shaft seal in the pump. It just sped up the demise of the pump is all. One thing leads to another..
Boog
Old 01-13-2019, 05:26 PM   #21
garyd1961
I replaced mine with a copper and brass one I found on line. I forget where I got it but it fit right and has worked great. There seems to be two different size cores, the wire hold downs won't fit if you get the wrong size.
Be careful not to break or lose the little clip on the cable that works the door. I found that plumbers putty makes the perfect sealer for the heater box.
garyd1961 is offline   Reply With Quote
