Big back window
I bought a cab with a big back window with minimal rust the problem is it look like someone used a can opener on the firewall. It has gaping holes in several locations. I have a extra cab to cut panels out to patch it. My question is are there any aftermarket sources for a firewall to replace or cover it with something like stainless?
Any help will be greatly appreciated |
![]() Join Date: Aug 2008
Re: Big back window
Moderator
![]() ![]() Join Date: Aug 2011
Re: Big back window
http://directsheetmetal.com/Store/in...ort=20a&page=2
https://www.selfmadefab.com/product/...rewall-shavers https://vannattafabrication.com/new-...oth-beadrolled http://www.yogisinc.com/index.cfm/pa...cat/cat507.htm http://modshopinc.net/store/index.ph...roducts_id=637
Master Chief, US Navy, Retired 1964 C10 Step-side Short Bed - In Progress 2009 2500HD Duramax LTZ 1948 GMC Panel 1956 Big Window Stepside 1953 5 Window Chevy Stepside 1932 Coupe New Seat Foam for Bench Seats? Last edited by The Rocknrod; 12-25-2018 at 11:44 PM. |
It's Better With Nitro
Re: Big back window
Depends on how bad yours is. The previous owners of my truck, cut and drilled a bunch of holes in the firewall and floor (88 extra to be exact). I spent a lot of hours welding, hammering and dollying my firewall.
![]() Join Date: Jun 2009
Re: Big back window
Its not BIG BACK WINDOW.
Proper terminology is Panoramic View 60-63 or Full View 64-66. No one cares , i'll be quiet now.
1963 Chevrolet Truck Literature LINK: https://picasaweb.google.com/113840717762774560215 YouTube Channel with 20+ Original Chevrolet Truck Salesmen, Mechanics & Service Department Training Slideshows. https://www.youtube.com/results?sear...otruk63&page=1 |
![]() Join Date: Apr 2017
Re: Big back window
Re: Big back window
Thanks for the links on the firewall panels and the education on proper window description.
I'm new to posting to this site so I hope the photo will up load ok. |
![]() Join Date: Feb 2014
Re: Big back window
Re: Big back window
Re: Big back window
Exception to the rule , but that applies to many things.
#11 | |
Re: Big back window
![]() Join Date: Dec 2018
Re: Big back window
At first I was going to joke and just tell you to cut some sheet metal and pop rivet it over the holes..... But after seeing the pictures..... WOW! What the heck where they thinking?
1965 Chevy c20 292 4speed http://67-72chevytrucks.com/vboard/s...d.php?t=777601 1976 Chevy c10 250 4speed http://www.67-72chevytrucks.com/vboa...d.php?t=787037 1978 Chevy c20 350 4speed 1998 Chevy c1500 4.3L 5speed 1999 Chevy k1500 Suburban 5.7L auto 4x4 2002 Chevy s10 4.3L auto 4x4 1971 Mercury Monterey wagon 400 auto Plus other misc. ... To many projects! |
#13 |
Re: Big back window
I look at them pics and all I can is WTFMF
#14 |
60-66 Nut
![]() ![]() Join Date: Mar 2007
Re: Big back window
And it's an AC cab as well. If the rest of the cab is decent, I think I would opt to just replace the entire firewall.
#15 |
Re: Big back window
The rest of the cab is in very good shape. I have another firewall. The question for the group is. If I cut the parts that have been mangled and patch them in will there be enough support or should I try and replace the entire fire wall.
#16 |
Re: Big back window
For me, it would take less time to replace the entire firewall. I would brace the cab, cut out the firewall, remove and weld in the firewall from the donor cab.
#17 |
Re: Big back window
Pardon my lack of experience but what do you mean when you say "brace the cab"?
#18 |
Re: Big back window
Since it appears that the cab is not mounted to the frame, and if you remove the firewall (a significant component to the structural integrity of the cab), it would be good idea to brace the cab before cutting out the firewall to keep it square while you cut, grind, hammer, weld, etc. Even if it was mounted to the frame, I would still tack weld in a few diagonal braces similar to this from a member on this forum:
#19 |
Re: Big back window
Thanks that's is what I thought you meant. I keep asking myself what was i thinking.
It will certainly be a learning process. I already have a runner that I am going to 454 in so I will have plenty of time to do the cab work |
| Bookmarks |
| Tags |
| 454 swap |
