Old 12-26-2018, 02:40 PM   #1
bigmoe
bigmoe's Avatar
Panhard bar for square body rear in my 65?
I've put a 84 front crossmember with 3" drop spindles in my 65 frame and I want to put the square body rear in back. I've got Jeep Cherokee coils for a 4" drop in back. Won't be a problem to weld the perches on. I'll match the pinion angle of the original rear. What are others doing for a panhard bar?
bigmoe is offline   Reply With Quote
Old 12-26-2018, 02:57 PM   #2
vin63
It's Better With Nitro
vin63's Avatar
Re: Panhard bar for square body rear in my 65?
While I don't have the same combination that you have, I run an Early Classics track bar from the driver side frame to the passenger side trailing arm.
1963 C-10: Deluxe-optioned cab, shortbed, fleetside
Pontiac 462 ci, Kauffman D-Port alum. heads
4L80E, narrowed sheetmetal Ford 9-inch
Tubular front and rear suspension
Custom 6-piston front disc and 4-piston rear disc brakes
vin63 is offline   Reply With Quote
Old 12-26-2018, 03:04 PM   #3
bigmoe
bigmoe's Avatar
That looks like what I need except it says for 5" drop and more. I wonder if the geometry would be okay for 4" drop?
Old 12-26-2018, 05:29 PM   #4
Grounded63
You won't want to match the pinion angle of the original rearend. You'll want to set it at what pinion angle the drop requires. Otherwise you'll need to shim it, to be correct later.
Grounded63 is online now   Reply With Quote
Old 12-26-2018, 05:48 PM   #5
bigmoe
bigmoe's Avatar
Yes you're right. I'm doing an LS conversion and I'm actually thinking I'll set my motor and tranny in the bare frame as soon as I get the trans back from rebuild. The stock rear is still in place. I'll be able check pinion angles and adjust the perches on the newer axle.
Old 12-26-2018, 06:44 PM   #6
michael bustamante
michael bustamante's Avatar
if youre running trailing arms I would order the super trac bar kit from early classic
1967custom
michael bustamante is offline   Reply With Quote
Old 12-26-2018, 06:51 PM   #7
The Rocknrod
Moderator
The Rocknrod's Avatar
I had the super track bar from ECE installed, I switched to the one from POL as it mounts to the pass side trailing arm lower to preclude possibly hitting the frame on that side. My frame is C'd also so it may make a difference.
Old 12-26-2018, 06:59 PM   #8
michael bustamante
it should, my ECE had a 2 locations to possably mount it as well
1967custom
