Old 12-26-2018, 07:59 PM   #1
chris989
Fuel pressure test
Does anyone know of a fuel pressure gauge for a TBI motor i can leave in place while driving, even if not permanent. Just want to monitor the pressure under a load to make sure it is keeping up.
I found plenty that can check the static pressure.
Thanks,
Chris
chris989 is offline   Reply With Quote
Old 12-26-2018, 08:21 PM   #2
sweetk30
sweetk30's Avatar
Re: Fuel pressure test
this place for adapter unit . http://www.rvmorsemachine.com/newproducts.htm
great people and never heard bad in years of them around .
for safety reasons you can not have fuel pressure in the cab of the vehicle . it has to be isolated if mechanical or electric sender . both in the end run about the same .
then a 0-30 psi electric from someone like auto meter . kind of like this in what ever flavor you like . https://www.autometer.com/2-fuel-pre...-fse-4420.html
i have the 0-100 psi for my 60 psi system i have on now .
fuel left / tach middle / engine vac right . . . and my dash pad is crap so no i didnt screw a gauge pod to a good dash pad guys . . . .
77-k30lb BIG truck build .
87-k30lb budget beater build .
85-k30lb the plow machine build .
85-c10sb summer fun toy .
HOLLEY SNIPER efi = worst case of p.i.t.a i ever had .
EDELBROCK pro flo 4 = best deal going so far . love my setup works great.
sweetk30 is offline   Reply With Quote
Old 12-27-2018, 12:03 AM   #3
kipps
I just went on amazon and got a fuel pressure test kit that included a barbed tee to schrader adapter. My truck had rubber fuel hose going up the backside of the engine(don't know if that was correct or not), so I cut that and put the tee in place. The fuel gauge and hose fit perfectly through the gearshift hole, and I could just glance at the floor board if I wondered if the fuel pressure was holding high enough. Safety -- big whoop
kipps is offline   Reply With Quote
Old 12-27-2018, 12:33 AM   #4
chris989
Did you have to modify the fuel line at the back of the TBI or did it fit inplace?
Old 12-27-2018, 01:28 PM   #5
sweetk30
sweetk30's Avatar
few tweeks of the line and it fits in place .
you take out the stock adapter/spacer unit and put this slightly longer unit in its place .
