So,.. Two tings
First: As I contemplate accomplishing a much needed tune up on my 350 SBC, I want to convert to HEI for my near daily driving of it. It seems those who went with a GM HEI distributor had the best results. (Yes?). In the wisdom out there, will this be the best to ensure the OEM tach will continue to function? (I read somewhere that someone put in an HEI from an '83 with very good results).
Second: I also want to install a 3 point seatbelt and shoulder harness. (The driving here in southwest Florida is very reminiscent of many demolition derbies I've attended)! I notice a 1/2" to 5/8" hole in the posts/panel behind the driver and passenger side panels. They have a "plug" tack-welded over them. I'm wondering if there is a threaded nut, etc., behind there to accept the mounting harness? (It almost seems like GM was anticipating the eventual reality of a required 3 point restraint system and got ahead of the curve). If this isn't the case,... anyone installed a sealtbelt with shoulder harness in their truck? Happy New Year!! |
![]() Join Date: Dec 2013
Re: So,.. Two tings
Yes ,install HEI . spark plugs need to be re gapped to .045-55
Yes, It's a plastic plug in the pilar not tack welded . 3 point seat belts bolt right in for about $175.00
![]() 1967 Factory short bed - Old school '71 - 350 / 4bolt / 487 heads / Edelbrock C3BX Muncie M-22 4 speed / Hurst Comp plus Factory 12 bolt posi 3.73 / 255-70-15 Smoothed firewall / Factory cowl induction Power disc brakes / power steering / 3.5-5" drop |
![]() Join Date: Oct 2009
Re: So,.. Two tings
I think member t korinek sells nice aftermarket 3 point seat belts. Other board vendors may also, I just seem to recall seeing his shown somewhere. Factory 3 point belts extremely rare.
OEM tach will function fine with or without an HEI. If you do swap in an HEI, you might consider adding a tach filter in the wiring. Some folks run them, some folks don't, worth reading up on before you install - lots of threads on here about it. LMC and several other places sell them. Last edited by jocko; 12-28-2018 at 01:14 PM. |
Re: So,.. Two tings
70 C20 - 3 point seat belts - I had a plastic plug over a threaded nut. Can't remember the thread, but it was a standard size.
1970 C20 Custom Camper - 350, TH350 1997 GMC Suburban 1994 Acura Integra GSR 1987 Dodge Daytona Shelby Z |
Re: So,.. Two tings
You may already know this: you'll have to source a 12 Volt ignition hot to power the HEI. Your original ignition hot (+) to the coil is voltage reduced for the point system and not sufficient for the HEI upgrade. Search the the forums here for the conversion.
Steve weim55 Colorado |
![]() Join Date: Dec 2009
Re: So,.. Two tings
The holes in my 67 cab for the three point seat belt holes
at the top of the cab are 7/16 diameter x 20 thread per inch.
________________________________________________________________________________________ ____________________________________________ The early bird gets the worm, But the second mouse gets the cheese 85 Chevy K-20 63 Impala (my high school car) http://67-72chevytrucks.com/vboard/s...Crew Cab Build |
Re: So,.. Two tings
HEI is a great upgrade and highly recommended, but it’s not just plug n play and has to be setup right. As already mentioned, you’ll have to replace the original power wire with an un-resisted 10-12 gauge wire so you’ll get full voltage to the HEI, and the plug gaps need to be adjusted to .045. To set it up, you have to verify your mechanical advance weights and center plate to see how many degrees of advance it gives (you want 20-22), change the mechanical advance springs so you’ll get full advance between 2500-3000 rpm, and verify your vacuum advance degrees (you want 10-15). If my memory serves correctly, GM HEI #19212081 or #1104067 should work well and you’ll only need to change out the springs and vac advance with those units. Just verify compatibility of those part numbers and you’ll be good to go. Get Crane’s vac advance kit (99600-1), it includes the springs and has an adjustable vac advance that will get you setup nicely. After all that, time it to 36-38 degrees total, plug the vac advance in to manifold vac, and it’ll be running like a champ.
Seat belts are real easy. Most vendors sell them with all the correct hardware. You just have to figure out which ones you like and the price point you're comfortable with.
72 C10 lwb fleetside -stock 350/350 combo |
Re: So,.. Two tings
Here's a really good thread from dmjlambert on replacing the resisted power wire:
http://67-72chevytrucks.com/vboard/s...d.php?t=708975
Re: So,.. Two tings
Some where on here someone did a swap with an s10 seat belts.His reason for doing the swap with the s10 is because he knew that the s10 belt would lock up in an accident.The after market seat belt suppliers couldn't give him a yes or no answer.
| Bookmarks |
