Old 12-28-2018, 10:37 PM   #1
twoskies
twoskies's Avatar
Hei Timing And Carb setup Help
hey
1979 350 with hei and rochester quadrajet, have timing set at 8 advance, secondary choke on carb is unhooked(was already like this) motor starts up on electric choke, primary door opens after a minute or two, motor then has to be set at a high idle or it wants to slowly lope down and die, it does start right back up and you can keep it running by feathering the gas
does run a little rough after choke kicks off
do i need more advance(have seen some setting at up to 16)
or is it possibly a carb issue , setup, or secondary choke that is not hooked up
thanks for any help
A Little Better Every Day
Cancer Survivor, most dont know what they have until its gone, appreciate everything
twoskies is offline   Reply With Quote
Old 12-28-2018, 10:49 PM   #2
jocko
jocko's Avatar
Re: Hei Timing And Carb setup Help
Initial advance is likely not your issue, 8 deg is more than sufficient to keep er going. What happens once it's warmed up (if you keep it running long enough by tapping the gas)? Does it eventually settle down and keep running? If you can get it to that point, recommend adjusting idle mixture screws. If you can't keep it running (or maybe try this first when it's not running), you can very carefully count how many turns it takes to seat the idle mixture screws (that way you can at least return to your current setting, depending on what you find when you try this). Approx 1.5-2 turns out from seated should be ball park. If you're close to that, I'd just reset it where it was. If not set to that, try that setting and see what happens. When you say high idle is needed to keep it running, how high? Is the engine up to temp on your temp gauge if your truck has one?
Old 12-29-2018, 01:00 AM   #3
geezer#99
geezer#99's Avatar
Got headers?
Working heat riser?
Stock air cleaner or not?
Got pics of your carb with and without air cleaner on.
Old 12-29-2018, 02:13 AM   #4
kwmech
It's winter and it's a carb'd engine. I have the same issue every winter with my 454. Cold blooded with a 4 core radiator...takes about 5-7 miles b4 everything is happy
Old 12-29-2018, 08:25 AM   #5
twoskies
twoskies's Avatar
hey
thanks for the replies, motor is out of a 1979 el camino, friend said it was a replacement motor, low mileage, dont know for sure, he had it on a stand when i looked at it, was alot warmer, seemed ok then, it did set for a few months inside garage before i got it in truck
no headers, stock dual exhaust kicks out right behind wheels
running an electric choke, i am running 12 volts to it
i do have a old replica cadillac batwing air cleaner on it, runs same with or without
i can set the idle screw in and it will run on its own
i can keep it running with the gas pedal
ill check the idle mixture screws, just bought a carb tool yesterday, mine had the double d screws, never knew there was a screw like that
and ill try to get a couple pictures today
thanks again
Old 12-29-2018, 11:49 AM   #6
twoskies
twoskies's Avatar
hey
just snapped a few pictures, also found the secondary choke is not hooked up, would this cause idle problems
thanks
Old 12-29-2018, 11:59 AM   #7
geezer#99
geezer#99's Avatar
That’s not a choke!
It’s the secondary air door. It’s spring loaded so it stays shut until needed.
Tap it with your finger and it should pop shut again.
Is the vacuum hose to that back vacuum pot hooked up or blocked off?
Old 12-29-2018, 12:16 PM   #8
rotten67
Have you checked for vacuum leaks? How old is the gas in it? Try cleaning or replacing the spark plugs. Are the points ok? Or does it have electronic ignition?
rotten67 is offline   Reply With Quote
Old 12-29-2018, 01:00 PM   #9
MySons68C20
MySons68C20's Avatar
He has the HEI....If it was mine I would pop the carb and at least give it a good cleaning and rebuild so you can rule that out.
Today's ethanol fuel plays havoc with the internals especially if allowed to sit for extended periods.
MySons68C20 is offline   Reply With Quote
Old 12-29-2018, 01:56 PM   #10
randy500
Looks like your curb idle screw is way in...should be about 1 turn open, it also looks like the secondary lever could be holding them open at idle, pull the secondary lever forward to make sure they are closed.
Base timing should be at least 16 so bump that up.
You have to forget about all the engine stickers saying base timing is 8, etc.
the engine wants 36 degrees at about 2k rpm. that Hei has about 8-10 centrifugal at that rpm and continues to provide advance to about 5k rpm, which is stupid but that's how they are set up.
Base 16
Centrifugal about 10 at 2k, another 8 or so at higher rpm
With 16 base timing your still short a lot of advance.....
Vacuum...only providing advance at high vacuum cruise conditions.
randy500 is offline   Reply With Quote
Old 12-29-2018, 01:58 PM   #11
HO455
HO455's Avatar
Sounds like you may only need to adjust your fast idle setting. When the engine is cold step on the throttle and " set the choke". This allows the throttle plate to open and the fast idle can to drop so when you release the throttle the throttle butterflies are open slightly. At this point you should see clearance under the idle set screw. If not then the fast idle adjustment is wrong. The carburetor should be holding the higher idle speed without your input. Setting the choke requires the parts to move free as gravity is the power source to move some of the parts.
Here is a link for some choke information and there are some videos out there on how to adjust the fast idle setting on your Qjet.
I recommend you look at the choke's operation first and make sure it is working correctly before adjusting anything else. If the truck runs good when warmed up, then my money is on the choke. You may find the choke mechanism has been assembled incorrectly in the past. Something I have seen many times.
https://www.hemmings.com/magazine/mu...t/2144991.html
Good luck.
RIP Bob Parks.
Old 12-29-2018, 08:13 PM   #12
twoskies
twoskies's Avatar
ok
again thanks for all the replies
i reset the timing to 16
adjusted the 2 dd screws to 2 turns out
still has to run fast at idle or it dies
might have found a possible issue(or at least not helping the problem, trying to adjust carb screws with the squeal sucked), alternator started squealing really bad, am going to get a replacement in the morning, also going to get carb filter
thinking about what someone said, pull it and rebuild, kinda leaning that way
ill update tomorrow
Old 12-29-2018, 08:25 PM   #13
GASoline71
"I ain't nobody, dork."
GASoline71's Avatar
How is your plug gap? With the HEI, it should be at least .045
Gary
'cuz chicks dig scars...
My 1972 GMC 1500 Super Custom (Creeping Death) "long term" build thread.
The Rebuild of Creeping Death after the wreck
Originally Posted by LONGHAIR View Post
I would never rebuild a 305.
Originally Posted by prostreetC-10 View Post
I love using vacuum gauges as part of the carb tuning process. I hook the gauge to the inside of my garbage can and leave it there.
Originally Posted by Marv D View Post
Remember Murphys 2nd law of mechanical relationships... "OPPOSING COMPONENTS ATTEMPTING TO OCCUPY THE SAME SPACE, AT THE SAME TIME, GENERALLY END UP OCCUPYING ADJOINING SPACE AT THE BOTTOM OF THE OIL PAN"
Originally Posted by cableguy0 View Post
Its cheaper to listen to advice given when you ask for help than it is to ignore everyone and wait for carnage.
GASoline71 is offline   Reply With Quote
Old 12-29-2018, 11:34 PM   #14
twoskies
twoskies's Avatar
hey
the plug gap is set at .045,
i have changed the plugs
ac R45TS
thanks
Jeff
Old 12-30-2018, 08:06 PM   #15
twoskies
twoskies's Avatar
hey
first, Thank You to all that replied,
some i had thought of others i had not
first i double checked my timing, 16 advanced, good
checked my dd carb adjustment screws, 2 turns out worked like a charm,
i did find my brake vacuum had a small leak( fixed)
adjusted idle to very acceptable speed,
i did remove the front vacuum, pretty sure i got it back on the same, even if not, when warm, truck runs good, so if i have to deal with choke issues, i can figure that out
Thanks again and
a very happy new year to all
Old 12-30-2018, 08:33 PM   #16
AussieinNC
Moderator
AussieinNC's Avatar
Are you running a thermostat?
You should have little to no radiator water flow until the thermostat opens...
Running headers you have no divorced choke feed back into the intake manifold heat passage further slowing warm up...
Suggest you look into a rebuilt carb and save the angst of fiddling with the old one...
Family and country before all others...
2006 Chevy Silverado (Daily Driver)
2025 Chevy Equinox
AussieinNC is offline   Reply With Quote
