11-22-2003, 02:34 AM | #1 |
Shaved door handle question
Hey guys. I need some help here. I bought a shaved door handle kit from AIM industries, and am wondering where to mount the solenoids to pull the handle/cable open. Also, which direction do I mount the solenoid brackets? Does it pull toward the front of the truck, or down? If any of you have pics of how they're mounted, please let me know. Thanks!
Kent Ballan ANY MAN CAN BUILD A TRUCK, BUT IT TAKES A REAL MAN TO CUT ONE UP! |
11-22-2003, 11:50 AM | #2 |
Whats this wire for?....
just put power to the solenoid and see which way it moves. a straight line is amost always best for the cable direction. I hooked mine up to the latch where the interior pull handle bar clips in.
Kyle CANADIAN CONNECTION '82 C10 Resto-Custom--> * 2 1/4" manifold back dual exhaust with Hooker Aerochambers & High Flow Cats *Taylor Ignition Wires *Centerline 15" Telstars with 32"x10" mudders |
11-22-2003, 04:35 PM | #3 |
It followed me home?
Adam That's why they call it a shortcut Kyle, if it was easy it would just be the way. 86 c-10 SWB 85 CCSB 90 GMC K30 Crew SRW 1985 C30 Dually |
11-23-2003, 03:09 AM | #4 |
I appreciate the replies. I don't think I was clear enough though. Sorry! What I need to know is which way the rod/cable pulls when you pull the handle (or push the button outside to open the door.) Does the rod pull toward the front of the truck?Which direction does the solenoid have to pull toward when activated? Thanks guys!
11-24-2003, 07:33 AM | #5 |
91 SWB 383
they pull up . i had to have them make a pull on them to work right . i can send the web address if u like . i just done this to my truck .
96 2dr Tahoe protruning LS1 347/4L60L, PSI harness, body dropped, 4link, 6lug conv, narrowed rearend, Schoenfeld headers, 2600 stall, 317 heads milled .040, http://photobucket.com/albums/q169/k...ahoe prostreet |
11-24-2003, 07:34 AM | #6 |
91 SWB 383
go to this web page and he'll help u with them . this is where i got mine from . i just trade mine for some all ready done .
http://www.customclassic.com/
