Old 12-29-2018, 01:40 AM   #1
mikebGMC70
Airbag/ panhard bar question
I apologize if this is a dumb question but here goes:
I have a 70 c20, converting to rear trailing arms and adding airbags. Question is when lowering or raising the bags does it put pressure on the panhard bar enough to push the rear end side to side?
mikebGMC70 is offline   Reply With Quote
Old 12-29-2018, 01:57 AM   #2
dayj1
Re: Airbag/ panhard bar question
Yes, the panhard bar is fixed to the frame at one end and moves in an arc as the rear end travels up and down. This results in the rear end also moving side to side. If you make the arc longer (as is often done with aftermarket bars) the result is less side to side movement.
dayj1 is offline   Reply With Quote
Old 12-29-2018, 02:44 AM   #3
mikebGMC70
That’s is what I thought. I am going to use a longer one from cpp. So do I get my ride height and set the panhard bar? Will low cruising cause any issues with the rear end being slightly kicked out from going up and down?
Old 12-29-2018, 02:09 PM   #4
HO455
Post Whore
HO455's Avatar
The amount of side to side will be acceptable if the panhard bar is level at ride height.
RIP Bob Parks.
