![]() Join Date: Sep 2005
Instrument Panel Cushions
I have looked all over and feel silly for asking...
Where do the styrofoam anti rattle cushions for the instrument panel lens go?
1969 C20 Customer Camper CST, 396, TH400, Factory A/C, Olive Green. |
Re: Instrument Panel Cushions
Here are the pictures I took when I disassembled my dash panel for R&R.
1972 C10 LWB, 350/350 Deconstruction began 5/2009, mostly completed restoration, 5/2017 |
#3 | |
Cluster King
![]() Join Date: Nov 2012
What you can use is a piece of vacuum hose and fill it will black silicone. It is very hard to find original ones that are still soft. And then I read the original post which does NOT ask where to find them ![]() Hope this helps, Tom
Contact me on all of your gauge cluster needs. I specialize in restoration, repair and parts sales for 67-72 Chevy and GMC trucks. email me at tbonegarris@yahoo.com I am also a dealer for Counterpart for gauge cluster parts only. Also see my facebook page, CG&C |
Thanks, that helps a lot. I had the cluster apart to freshen up and install a tach and there were no cushions there.
I don't have the cushions in my cluster. And it doesn't rattle or anything.
( second times the charm) 71 gmc c15 307 sbc 373 rear gears positrac sm 465 trans. ( not listed on spid but is original )94 chevy k1500 350 tbi 373 rear gears 4l60e one wheel peel. Gutless 07 gmc sierra classic rcsb 4.3 lt 5 speed w/t 04 chevy Silverado 1500 ext cab 5.3 4l60e. 81 chevy Scottsdale k10 muncie sm465 Np208 10 bolt 8.2 ( Old Green) |
Old member
Small pieces of black foam work really well for this. Cut them to what ever size you need and they will last forever. Nobody see them so no harm done.
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver Seeing the USA in a 71 ![]() Upstate SC GM Truck Club 2013,14 and 2016 Hot Rod Pour Tour http://upstategmtrucks.com/ Get out and drive the truck this summer and have some fun! It sucks not being able to hear! LWB trucks rule, if you don't think so measure your SWB! After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs. |
I used foam rope from the hardware store on mine. It is used to stuff in cracks around windows and as a backer for large cracks before caulking. it comes in a bag for a couple of dollars. lifetime supply.
![]() Join Date: Feb 2002
Or you could get a tube of RTV, cut the conical nozzle to the right diameter [1/8''?], and squeeze a long line out on some wax paper. In 24 hours when the RTV has cured, cut the line into the required lengths.
![]() Join Date: Sep 2014
![]() I learned something new today great idea!!
| Bookmarks |
