12-29-2018, 10:44 AM | #1 |
New Exhaust Manifolds hitting starter - any ideas?
I bought a pair of cast exhaust manifolds from Summit - I installed them and noticed they hug the block pretty tight. I tried putting the starter in and found that the manifold actually hits the starter.
Link to the manifolds I bought: https://www.summitracing.com/parts/s...make/chevrolet These summit manifolds appear to be a copy of the popular Hooker Manifolds many people are using. Any ideas? Do I need to use a different starter instead? It looks like maybe if I took the heat shield off the starter it may barely clear, but not crazy about that idea- I searched and didnt find much on this issue. |
12-29-2018, 07:39 PM | #2 |
Re: New Exhaust Manifolds hitting starter - any ideas?
I would remove the heat shield, and test fit the pipe. If it it fits, I would trim the heat shield the least amount possible to get everything to fit.
Edit, and check the clearance on your transmission too. |
12-30-2018, 10:02 AM | #3 |
According to summit racing they don’t clear the starter or bell housing on 04 and 06 GTO what did yours come out of also doesn’t fit ls7 or ls9
12-31-2018, 01:30 PM | #4 |
Mine is a 5.3 from a pickup truck. I spoke with Summit and I can return them so I am going that route and will probably look for some LS3 camaro manifolds.
12-31-2018, 01:59 PM | #5 |
My Manifold are from a Pontiac G8 and are probably the same as the ls3 I read an article that said That they preform just as well as the aftermarket Castmanifolds
01-03-2019, 12:21 PM | #6 |
Just as an update here - I returned the manifolds to Summit and found a set of 2010-up Camaro LS3 manifolds locally along with the factory downpipe and cat convertors still attached. I mocked it up and it all fits really well, so the LS3 manifolds are a good choice it seems.
