12-29-2018, 03:19 PM | #1 |
Emissions Override Relay Wiring?
I picked up a '86 Chevrolet C30 CCDRW with a 454. The PO did a number on the wiring harness, so I pulled the engine harness and am in the processing of cleaning it up.
What I have left is wiring for 2 modules that I am trying to determine what they are (included pictures below). The numbers off the modules are: 14094774 14087500 After some research I am thinking the 14087500 is an "Emissions override relay" and the 14094774 is an "Electronic brake control" relay. Are either one of these accurate? Also, I am in the process of cleaning up the wiring to them and for module 14087500 it has a 5-wire weatherpack connector where in my case - Yellow and brown wires have been cut - Black wire has been crimped together with the other black wire from the other module for a ground. - White wire runs to the plug that goes into the HEI distributor - Pink wire runs into the other module connector. Does anyone know what any of these plugs do and if I can re-wire the harness to remove one or both? Thanks for all the help.
"Dixie" - 1988 Chevrolet V30 CC DRW "3+3" | 7.4L 454 (L19) | TH400 | 4" lift | 35"s "Lucille" - 1949 Chevrolet 3100 (on hold) |
12-29-2018, 10:46 PM | #2 |
Moderator
Re: Emissions Override Relay Wiring?
14087500 See http://67-72chevytrucks.com/vboard/s...d.php?t=616003
14094774 controls the Malfunction Indicator Lamp and maybe the BRAKE lamp on the instrument panel. Doncha just love the Red Green style wiring fixes you find on older rigs. Those plugs are Metripak. Probably Metripak 150 but they could be Metripak 280 series. You should be able to find both modules in the 1986 wiring diagrams. The part number for the connectors is in the wiring diagrams and it should tell you exactly what they are and where the wires are routed.
1959 M35A2 LDT465-1D SOLD 1967 Dodge W200 B383, NP420/NP201 SOLD 1969 Dodge Polara 500 B383, A833 SOLD 1972 Ford F250 FE390, NP435/NP205 SOLD 1976 Chevy K20, 6.5L, NV4500/NP208 SOLD 1986 M1008 CUCV SOLD 2000 GMC C2500, TD6.5L, NV4500 2005 Chevy Silverado LS 2500HD 6.0L 4L80E/NP263 2009 Impala SS LS4 V8 RTFM... GM Parts Books, GM Schematics, GM service manuals, and GM training materials...
And please let us know if and how your repairs were successful. |
12-30-2018, 12:21 AM | #3 | |
I had come across that link for 7500. According to that, that module is for a 350 not for the 454. Would it be possible to re-wire the harness to bypass these modules?
12-31-2018, 12:20 AM | #4 |
Bumping this - has anyone removed this completely out of their harness? Anyone who did a swap?
12-31-2018, 12:31 AM | #5 |
Moderator
I never had a truck with either one of them so I'm not going to be much help.
