Old 12-30-2018, 12:54 PM   #1
Sheepdip
Sheepdip's Avatar
They worked as advertised
A big shout out to "Full Custom Fab" in Texas for my seat lowering brackets. In all my years of playing with these 67-72 trucks I never knew there were 2 different heights on the seat rails, 5" or 7".
You have to measure what yours are and order accordingly, mine were 7. They bolted right in with no problems, they are a little tight to get to the rear bolts but doable none the less. A perfect fit!
I ran a tap thru the holes (5/16"-18) and took a electric solder gun to make clearance at the carpet around the holes to make sure I was not fighting those two battles and it went smooth as can be expected. A ratcheting box end is almost a must for the rear bolts.
I now sit 2" lower as promised. Well worth the $100
Sheepdip is offline   Reply With Quote
Old 12-30-2018, 01:12 PM   #2
Boog
laying low
Boog's Avatar
Re: They worked as advertised
2 different height brackets is news to me. I guess maybe the difference in brackets is the depth of the seat foam maybe? Standard and deluxe seating?
Boog
Old 12-30-2018, 01:42 PM   #3
saxart
saxart's Avatar
Do these brackets tip the seat back more, or just lower it?
Meet "Old Roy": http://67-72chevytrucks.com/vboard/s...d.php?t=707801
saxart is offline   Reply With Quote
Old 12-30-2018, 02:42 PM   #4
Coley
Coley's Avatar
2 Different seat heights?....from the factory?.....5" or 7"?
Wow, that's news to me. I'll have to check to see what I have.
Boogs point about it perhaps being tied to the full foam seat option might have something to do with that.
That is almost its own thread....what seat height do you have?
All good
Coley
....for some men, there is experience, skill and effort....for the others...there is visa and UPS LOL
1966 Chevy 1/2 ton (Florida- Red/white)
1972 Chevy 1/2 ton (California- Blue/white)
2005 Chevy Silverado HD2500/Duramax
2000 Dodge Ram 1500
Coley is offline   Reply With Quote
Old 12-30-2018, 03:19 PM   #5
67swb72klb
67swb72klb's Avatar
News to me too..
Here is a link https://squareup.com/store/full-cust...rackets-tall-2
California 65 GTO---Texas 64 burb 283 ---Oklahoma 67 CST SWB BBW wood bed 327 2004r---New Mexico 72 k10 350 350 auto---Georga 72 short step project
67swb72klb is offline   Reply With Quote
Old 12-30-2018, 03:24 PM   #6
flattie39
Junior Member
The factory seat brackets on my "new" 69 C10 Stepside are 7". I ordered the lowered brackets before Christmas and they should be delivered by Wed.
Flattie39
flattie39 is offline   Reply With Quote
Old 12-30-2018, 03:32 PM   #7
brownsville
brownsville's Avatar
love mine as well pretty simple install and it makes the truck more comfortable huge improvement
brownsville is offline   Reply With Quote
Old 12-30-2018, 04:21 PM   #8
Boog
laying low
Boog's Avatar
Or are these just an aftermarket way of lowering the stock seat for a head clearance or leg clearance issue? I like the idea anyway.
That 2" could give a big ol boy leg to steering wheel clearance with a non tilt column and stock size wheel.
Boog
Old 12-30-2018, 04:35 PM   #9
Sheepdip
Sheepdip's Avatar
Lower it only...you lose your factory adjustment rail and are limited to about 1-1/2" of slotted adjustment in the new brackets.
I'm very happy with mine, I was looking out thru the tinted top of the windshield
Old 12-30-2018, 05:20 PM   #10
Noah96
Happy to see these reviews ordered some after christmas should be in wed. I was also looking out of the tint looking forward to the install
Noah96 is offline   Reply With Quote
Old 12-31-2018, 09:44 AM   #11
Bingo! There was only one height of brackets. Full foam seat put you higher.
Old 12-31-2018, 11:18 AM   #12
Sheepdip
Sheepdip's Avatar
I am certainly no expert but their website clearly states factory tall and short brackets.
https://squareup.com/store/full-cust...s-tall-2:gmc2:
Old 12-31-2018, 12:25 PM   #13
saxart
saxart's Avatar
He sells these same brackets for the 60-66 trucks as well. Could it be possible that those trucks have two different height seat brackets?
I guess I’m going to order the “short” brackets for my ‘70 since I need more head/gut room.
Old 12-31-2018, 01:09 PM   #14
Sheepdip
Sheepdip's Avatar
I would measure what you have, if you have 7" tall and order the short 3" brackets you will not be able to get your hand in there to install the bolts, in fact your seat bottom will be on the floor.
It all has to do with where the bracket mounts on the seat frame, evidently for whatever reason there were 2 different locations of attachment.
Old 01-01-2019, 03:57 PM   #15
Noah96
Just bought these and installed in my truck big difference with factory steering wheel. Make sure to measure the rear of the original sea bracket!! My truck had the "tall" bracket but removing seat and tearing down about a 45 minute to 1 hour job. Personally I think its worth the money
Old 01-01-2019, 06:05 PM   #16
Boog
laying low
Boog's Avatar
Well the website shows pics of both 5 and 7" factory brackets. I was not aware of it. Did anybody notice their return policy? No Returns hmm.
Boog
Old 01-01-2019, 07:13 PM   #17
dsy1
When I needed to lower my seat I just cut the factory bracket down, re-welded it, and installed. I got the seat lowered as much as possible and kept the full factory forward/back adjustment. Cheaper, too.
dsy1 is offline   Reply With Quote
Old 01-01-2019, 07:48 PM   #18
KQQL IT
At the body shop.
KQQL IT's Avatar
Not their fault you cant measure.
" That didnt make it any newer "
" Dont antique the equipment "
KQQL IT is offline   Reply With Quote
Old 01-01-2019, 08:11 PM   #19
Boog
laying low
Boog's Avatar
Oh I'm not buying from them anyway. But you know it is bound to happen. I'm just saying.
Boog
Old 01-01-2019, 10:30 PM   #20
KQQL IT
At the body shop.
KQQL IT's Avatar
I'm planning on them soon.
And while I'm there removing the gas tank in the cab as well.
