12-30-2018, 07:05 PM | #1 |
dropping a gas tank
1989 v2500 burb.
Any advice on dropping the gas tank on a burb. Anyway to change the pump without having to remove the tank? I want to change the pump before it lets me down. It is the single tank rear of the axle. thanks, Chris |
12-30-2018, 07:16 PM | #2 |
Re: dropping a gas tank
run it almost empty .
start spraying hardware with oil / lube / p.b. blaster / liquid wrench . floor jack with good size pad on it like plywood . few new hose clamps for stockers that will prob fall apart if you live anywere near the rust belt . 16mm and 18mm line wrench for hose fittings . there NOT included in most line wrench sets . ACDELCO https://www.rockauto.com/en/moreinfo...301117&jsn=491 pump and sock is what you want to put inside when you do it . sock https://www.rockauto.com/en/moreinfo...301117&jsn=507 and if your looking to bump performance now or later go with a bigger pump like this 1995 454 c30 pump https://www.rockauto.com/en/moreinfo...034569&jsn=667 holds higher pressure . the stock tbi pump was lucky to hit let alone hold the 13-15 psi they should run . lots of guys bump up to the later 454 pump and have good results . its also plug and play no mods required to install it . some guys with older beaters or off road trucks cut a hole in the bed to make a acssess port for the sender .
77-k30lb BIG truck build . 87-k30lb budget beater build . 85-k30lb the plow machine build . 85-c10sb summer fun toy . ----------------------------- HOLLEY SNIPER efi = worst case of p.i.t.a i ever had . EDELBROCK pro flo 4 = best deal going so far . love my setup works great. |
12-30-2018, 07:19 PM | #3 |
I have a trans jack and all the tools, I was hoping i could access it from inside but i just removed the rear carpet and no such luck. If I knew where to cut,, I would fab a door in the floor for future access.
Thanks, |
12-30-2018, 07:59 PM | #4 |
i know guys have listed the specs online before . but i never took them down since i am a truck guy my self .
12-30-2018, 10:14 PM | #5 |
the tank came down easy enough but i can not get my strainer off of the old pump. What is the secret?
never mind,,,, it just needed more force than i thought,, i did not want to tear the strainer |
12-31-2018, 12:29 PM | #6 |
always replace the strainer sock .
and there a finger grip on the pump body .
12-31-2018, 01:27 PM | #7 |
Moderator
Don't put that baby back in with the original sock.
It voids the warranty on the pump... When it disintegrates the pieces jam the pump. I'd cut a window in the floor under the carpet and cover it with a piece of floor patch panel. Use butyl or something similar on the edges to keep the outside out.
1959 M35A2 LDT465-1D SOLD 1967 Dodge W200 B383, NP420/NP201 SOLD 1969 Dodge Polara 500 B383, A833 SOLD 1972 Ford F250 FE390, NP435/NP205 SOLD 1976 Chevy K20, 6.5L, NV4500/NP208 SOLD 1986 M1008 CUCV SOLD 2000 GMC C2500, TD6.5L, NV4500 2005 Chevy Silverado LS 2500HD 6.0L 4L80E/NP263 2009 Impala SS LS4 V8 RTFM... GM Parts Books, GM Schematics, GM service manuals, and GM training materials...
And please let us know if and how your repairs were successful. |
