Old 11-22-2003, 01:22 PM   #1
intrigued
oil spray
ive got an edelbrock intake w the oil filler tube in ive got oil spray all over the intake . i bought a new pcv valve still spray i know my carb needs rebuilt. my stock carb im waiting to rebuild my holley im about ready to put my 305 back in
intrigued is offline   Reply With Quote
Old 11-22-2003, 03:02 PM   #2
toytruck
5-7 dropped 87 CC Dually
toytruck's Avatar
Could use a little more info here. Power wash the motor and tell us where it is coming from.
I rather be in my 77 Sanger Picklefork Jet Hydro!
toytruck is offline   Reply With Quote
Old 11-22-2003, 04:00 PM   #3
intrigued
its coming out of the filler tube
Old 11-22-2003, 04:06 PM   #4
74Pumpkin
Insert witty comment here
74Pumpkin's Avatar
The only reason it would be coming out of the Filler tube that I know of is,
1. You don't have a baffel in you valve cover. ( If this just started then that is most likely not the issue.)
2. Ventalation of you crankcase is not working properly.
If you relplaced you PCV valve the you need to check to see if the vacume is it hooked up and working. Vacume lines cracked or disconnected? Is it hooked up to the right port?
I'm not sure if this is the prob but I would start there.
So many trucks, So little time!
74Pumpkin is offline   Reply With Quote
Old 11-22-2003, 04:10 PM   #5
toytruck
toytruck's Avatar
Do you have a breather on the other valve cover?
Old 11-22-2003, 04:10 PM   #6
intrigued
when i dropped the engine in i bought new lines tried differnt ports its been doing from day one
Old 11-22-2003, 04:26 PM   #7
intrigued
i was going to attach pix but i cant
Old 11-22-2003, 04:37 PM   #8
toytruck
toytruck's Avatar
I'm leaving to go hunting. You can send it to me. I'll look at it when I get back. toynova@aol.com
Old 11-22-2003, 09:35 PM   #9
toytruck
toytruck's Avatar
I got the pic but I can't post it either. In this reply form is says that I may not post attachments- Smilies are on. Funny I could yesterday.
Old 11-23-2003, 01:10 PM   #10
toytruck
toytruck's Avatar
motor pic
