Old 12-30-2018, 09:41 PM   #1
rjs53
1969 C10 water pump
Ok so in my 69 c10 I have a sbc350. This truck came with a 350ci, but not the one that's in it. The motor I have now is out of a 1978 K10 or 2500, according to the numbers I've found on the motor. The Po I got it from I'm assuming put this in. The water pump is a long pump and the outlet to the bottom hose is clocked to far down, causing the lower radiator hose to kink on the frame. I got a water pump for the 69 year but no provisions for the power steering or alternator. Alt is on passenger side. I don't want to buy new brackets, was wondering if anyone else has run into this and what you may have done? Pictures if you got em of your set up. Thanks
2003 Dodge 2500
1969 C10
2014 Camaro SS/RS/1LE
rjs53 is offline   Reply With Quote
