Old 12-31-2018, 01:37 PM   #1
Ewr101
Ewr101's Avatar
Simple Questions I can't find an answer for
72 Blazer w/ TH350 transmission- When changing the transmission dipstick 1- can I swap the tube out for a later one with a grommet seal without any problem? and 2- does the fluid need to be drained to do the swap or can I swap it while it's full? I was caught without a pan when swapping the speedometer bullit. Don't want to repeat that. Thanks!
72 Chevy 2WD Blazer
Ewr101 is offline   Reply With Quote
Old 01-01-2019, 03:36 AM   #2
72k5ls
Re: Simple Questions I can't find an answer for
You will need a drain pan under it you are going to spill some when the dipstick is removed.
72k5ls is offline   Reply With Quote
Old 01-02-2019, 04:26 PM   #3
jaros44sr
jaros44sr's Avatar
There are good chemicals on the market to remove oil stains from your driveway, if you choose not to use a pan
I'm using dipstick from Locarr
Semper Fi...Uncle Sam, you da man
All parts offered to help are free, unless otherwise noted
Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training
SAFETY FIRST
AS usual, off topic
They say your mind goes second, can't remember the first
Jim
jaros44sr is offline   Reply With Quote
