Old 12-31-2018, 10:56 PM   #1
bigmoe
bigmoe's Avatar
Help bolting 5.3 and 4L60e together
I bought an '08 Tahoe 5.3. It came with the flex plate. I didn't get the trans because it was a 4x4. I found and bought a 2wd Silverado "08 4L60e and torque converter.
I've got:
-flex plate
-Bell to motor bolts
-Torque converter bolts
-Dipstick and tube
-Ordered a big plastic dust cover
-need a starter
Is there anything else? No thin metal plate at the back of the motor?
bigmoe is offline   Reply With Quote
Old 01-01-2019, 12:53 PM   #2
bigmoe
bigmoe's Avatar
Re: Help bolting 5.3 and 4L60e together
One more thing I discovered searching around. There's a piece of plastic under the starter that has to be removed to get at the torque converter bolts. Not sure what it's called.
Old 01-01-2019, 01:51 PM   #3
mongocanfly
Post Whore
mongocanfly's Avatar
the trans I swapped for a buddy of mine I had to take the starter off to get to the t/c bolts
Mongo...aka Greg
RIP Dad
RIP Jesse
2023 Chevy Z71..daily driver
Old 01-03-2019, 09:44 PM   #4
Dustytrix
Its just a dust cover, not really needed. But like said above you still have to pull starter to get to converter bolts.
Dustytrix is offline   Reply With Quote
Old 01-03-2019, 11:59 PM   #5
bigmoe
bigmoe's Avatar
Maybe not needed but I wonder if the starter would be louder without it?
Old 01-04-2019, 12:18 AM   #6
kipps
I've separated three engine/transmissions so far. A TBI 350 with a manual, A 4th gen 5.3(2010) with a 6l80e, and a Ford 300 I-6 with a manual.
The Ford had that thin metal plate you describe. Neither GM did. They simply mated the bellhousing to the block.
kipps is offline   Reply With Quote
Old 01-04-2019, 01:48 PM   #7
bigmoe
bigmoe's Avatar
I've done several Fords and was used to seeing that plate. I guess GM's don't have them.
Old 01-04-2019, 04:05 PM   #8
kipps
Try part no. 24261712 for that plastic dust cover. It is held on with one bolt, and then the starter mounts through it.
Old 01-05-2019, 11:22 AM   #9
bigmoe
bigmoe's Avatar
Got one from my local wrecker. He said they throw them out but he happened to have a truck being torn down when I was there so I snagged it.
Old 01-06-2019, 06:56 PM   #10
bigmoe
bigmoe's Avatar
I had someone suggest to me that I should buy a set of Allen head bolts to attach the trans. He said if I ever have to pull the trans the upper two bolts are difficult and the Allen head ones would make it easier. I’ll keep the one stud style one for the dipstick though.
Old 01-15-2019, 01:49 PM   #11
goofy063
just cut the stud part off your bolts i personally would never use allen head bolts
goofy063 is offline   Reply With Quote
