inefficient heaters
why do they have to put such inefficient heaters in vehicles, never had a vehicle with what I would call a good heater, and most fans couldn't blow out a candle, anyone have this grip, and what to do about it Brrrrrrrrrrrrrr, dam its cold here
#2 | |
Designated A-hole!
"If it ain't broke, fix it 'til it is!" Being stupid ain't illegal. ![]() We're Still Debt Free Except for the House!!! www.daveramsey.com 70 GMC SWB Stepside project "Green Booger" soon to be 6.0l/4l80e 93 S-10 "Poppaw's Truck" |
If you're referring to your truck, casey, you may need to adjust the cables for air flow. My 69 blows a lot of volume, and will cook ya out after a short time! Make sure the mice haven't built a nest in the diverter box! Seems to be a favorite place in mine!
69 GMC K10 ..some restoration required....still.. ![]() |
or the heater phlenum could be filled with crap
Yup, if everything is working right, no rats nests and a 195 degree thermostat, these trucks have an awesome heater.
Tim |
![]() Join Date: Mar 2000
My heater wasn't up to snuff a couple of weeks back and I can't fit the truck in the garage so I took it to my buddy that has a rad shop. The core was plugged and was able to be rodded out (most are not worth it) the air door was out of adjustment and the plenum around the core was plugged with crap. He had to completely disassemble the housings to get all of the crap (dead leaves and such) out. It blows so hot now you can't keep your hand over the def vent and it's -25 degrees C out there today.
Saskatoon, Saskatchewan Canada |
Recovering 67-72 Addict
![]() Join Date: Oct 2000
Mine will cook you out too. Check for holes in the firewall and a good seal on your fresh air doors. These things will cool you down quick if your driving around below 32 deg F.
68 Short Fleet 4x4; 427; BTO Level 3 700R4; NP205; Dana 60 front and rear; 4" lift with 35's; Disc brakes; AGR variable ratio steering; factory bucket seats; factory tach and tilt. "Friends call me cruzer cuz I like fast cars and fast women" |
Krue I'd move in a heart beat if I could, but in reality, looks like my heater system needs some attention, if you guys are getting good results, then mine must need some work, I'll start with your guys suggestions, thanks
It's got to just need a good cleaning. I recently removed my blower and it had about two hand fulls of junk in it. Years ago I took a hose and ran high pressure backwards to clean out and that helped on an old 49 I had.
Designated A-hole!
Wuz just funning you, my blower motor doesn't work but the radiated heat is enough to get the cab hot. Like the guys said if working properly it should run you out of there.
its all about the +6 inches
ONe thing, if your truck originally came with A/C, the heater will put out more air flow, and i am willing to bet quite a bit more heat too. I have never seena non A/C truck that would "run you outa the cab", but every A/C truck i have ridden in would make you sweat though.
My heater is marginal at best. |
neither of my heaters work. it really sucks. but i dont drive them yet so im ok with it. eventually vintage air i hope
70 longbed 496/th400/Ford 9" |
#13 |
PROJECT 7DEUCE
![]() Join Date: Dec 2002
Both the heter's I have suck. The blazer is like trying to warm up an ice box and the truck is so/so on the heat department. Both are non a/c truck's.
GO BIG GREEN ![]() MEMBER #6377 72 k-5 daily driver 6'' lift 35'' 350-350-205 slowly getting rust free. Project "7DEUCE" check out my build http://67-72chevytrucks.com/vboard/s...d.php?t=267665 Tim Powell..R.I.P EastSideLowlife..... R.I.P.. |
#14 |
Firefighter
I just totally redid mine awhile back and it's on a non-A/C cab and it will run you out of the cab even on the coldest days!!
'72 Chevy SWB 350 Auto '67 GMC LWB 350 4 speed '70 Chevy 4x4 Stepside 350 Auto Yellville, Ar. USA ![]() ![]() |
#15 |
Put an AC fan into your non-AC truck
Although I haven'd done this as I haven't seen it necessary, I've heard that putting a fan for an airconditioned truck into one without air conditionong helps a lot. If any one does this, let us all know.
#16 |
my non ac truck will run you outta the cab after 15 minutes or less. most of the time in the dead of winter i will have at least one wing window open just so its nice and comfy. there is no junk in my heater box and my heater core is fairly new
Owner of North Point Car Care in Dundalk Md. We specialize in custom exhaust on both modern and classic vehicles. We are a full service auto shop from classics to modern vehicles. Feel free to contact me with questions. I will give a 10% discount to any board member. |
#17 |
![]() Join Date: Feb 2003
heater
I plow snow in my non-A/C truck in very cold weather with just a shirt on my upper torso. I have 3 other non-A/C trucks that heat just as well. Like stated above, they have to be maintained for coolant flow & air flow. I did have an A/C blower motor in there for awhile & it did flow more air.........Zoomy
#18 |
THis is interesting.
Mine has a new blower (non A/C..I was concerned about putting that many amps in the harness that was not designed for it) , a new heater core, minimal crap in the heater box and I warm up the cab more when i fart than whats coming out the vents. I do admit and realize that I have quite a drafty truck, however, the air temp coming out the vents is hardly enough to defog...let alone defrost my glass. |
#19 |
Designated A-hole!
Mine will defog w/o a blower at all. You need to check your heater dude! Especially living way up north and all.
#20 |
Firefighter
Yeah, even before I fixed the blower mine would still defog the windows. If yours does not run you out of the cab or make you turn it down/off, or open a window/vent window then there is a problem some where!!! All 3 of mine will make it very hot in the cab, I also worked on a buddy's and got it working like that and he has NO lower kick panel vents, only gaping holes!! Check to make sure the hoses are routed properly and are in good shape, check the thermostat, check the heater box for trash and to make sure it's seals are good, check the heater core, check your door flappers to make sure that they are operating properly, check the cables to make sure that they are actually moving all the way that their supposed to, and then check your switch to make sure ALL THREE positions work, then you could close any obivious holes that you may have. After doing this you should have no problems.
#21 |
I recently converted my non-AC cab to an AC cab. BOTH configurations, when I have everything working right, will get too hot if you let it run.
One easy thing to try if you're not getting much heat is to burp and fill your radiator. If you don't have an overflow bottle on your radiator, and most of us don't, you may have some water capacity that is currently full of air. Also as far as I know there is no difference in the blower fans.
'70 cab, '71 chassis, 383, TH350, NP205. '71 Malibu convertible '72 Malibu hard top Center City, MN |
#22 |
There is a differance..the A/C one is rated at more amps, and spins faster. The A/C trucks have a blower relay for the hi position where the non A/C do not.
#23 |
Hmmm, thanks for bringing this thread up. Had it not been mentioned, i would have never realized how drafty my cab actually is.
I warmed up the engine and fired up the heater. I still have my summer T-stat in there, but a 195 degree one will find it's way in there shortly. With the engine at 170-ish, I was 120 degree air out the vents. Since even after an hr of driving, the air temp was no more than 60 degrees, I guess most my heat is going right out the seals and holes. |
