Tell me whats wrong with my 1966 chevy
first off I dont drive my truck very often. Recently I had the truck at my property and wanted to drive it to my house (15 mins away)
the truck started up and ran great for about 20 seconds and just shut off. like I turned the key off. So I ended up just putting it on the car hauler and brought it home. did some checking and its getting voltage to the distributor (HEI) but no spark to the plugs. checked the power to the coil its at 12 volts on the "on" key position then I got to turn the motor over voltage goes to 9 volts. Also when the key on the tail lights come on and my tach light. Which that is suppose to go off the light switch. I know its a switchI need to change just which one?
1966 Chevy C10 Stepside 355ci sbc with 3speed OD 2021 GMC Sierra 1500 AT4 6.2 1980 Chevy Camaro z28 383ci 1990 Chevy Suburban 350 tbi 2x4 (sold) 1984 Chevy C10 sliverado short fleet 1997 Chevy C1500 short fleet |
![]() Join Date: Sep 2006
Re: Tell me whats wrong with my 1966 chevy
Sounds like the module in the dist. Same thing happened to me and the dist was new.
"A man and his truck, what a beautiful thing" 65 Short Fleetside BBC 65 Long Fleetside 283 3 on the tree for now. my build thread http://www.67-72chevytrucks.com/vboa...d.php?t=259536 |
Have had that happen a couple times as well and coil a time or 2.
Disconnect the TACH wire from HEI Dist Cap You probably have a short from lights to TACH circuit. If it starts check under dash at TACH gage for wires shorted or light circuit connect to TACH wire circuit. TACH wire should be solo wire from Distributor TACH to TACH gage nothing spliced in.
#5 | |
![]() Join Date: Dec 2009
I vote for module
1977 Chevrolet K10 SWB Project 350/4spd/np205 1977 Chevrolet K20 LWB 350/350/203 1991 4Runner 22RE 5 SPD Yanmar Tractor 3 Cyl Diesel |
![]() Join Date: Feb 2011
Also check the rotor they are known to burn a hole in the plastic rotor and ground out on the shaft.
