Active Member
![]() Join Date: Aug 2012
Brake Conversion light duty spindles using Camaro 1LE Rotors.....
I'm planning a swap using a '80 or earlier crossmember on a '64. I want 4.75" X5 bolt pattern.
I know that by using the 1LE Camaro rotors on the light spindles you get the smaller bolt pattern. My question is will the light duty truck calipers work on the Camaro rotors? I know someone will ask me why I want this combination. Just because, I have a garage full of the Chevy wheels to fit. Any help appreciated. |
Moderator
![]() Join Date: Dec 2012
Re: Brake Conversion light duty spindles using Camaro 1LE Rotors.....
Should be the same as the 77-96 B car 12" rotor caliper. That's what the 1LE rotor is, the big Caprice rotor, but the small pattern.
