Old 01-01-2019, 09:02 PM   #1
Arl37
Hydraulic lifter Collapse?
I went to adjust the valve lash on my SBC 350 today. One of the rockers required much more tightening to eliminate the clicking than the others. In other words, the amount of exposed thread above the adjusting nut was much greater than on the other rocker studs.
I wonder what could have caused this.
I would appreciate you thoughts on this.
Arl37 is offline   Reply With Quote
Old 01-01-2019, 09:04 PM   #2
davischevy
Post Whore
davischevy's Avatar
Re: Hydraulic lifter Collapse?
There is a good chance the stud has pulled out of the head.
other Larry
Build thread, Arkansas K10
https://67-72chevytrucks.com/vboard/...=755797&page=5
The ability to speak several languages is an asset, but the ability to keep your mouth shut in any language is priceless.
davischevy is offline   Reply With Quote
Old 01-01-2019, 09:31 PM   #3
Arl37
Thanks for your comment, However, heads are Edelbrock E Street and i don't think the rocker studs screw directly into the heads. There is a plate for each cylinder on the head with a rocker stud on each side of the plate.. There is a bolt on each side of the plate that secures the plate to the head.
I will check this tomorrow.
Something's not right
Old 01-01-2019, 09:49 PM   #4
Mike C
Mike C's Avatar
The plates should be push rod guide plates that are required with aluminum heads, so you are correct that it would not pull out. Flat tappet cam? I'd be worried you wiped a lobe.
44 Willys MB
52 M38A1
64 Corvette Coupe
68 Camaro 'vert LT1 & TH700
69 Z/28 355 12.6's @110
72 Jimmy 4WD 4spd 4" & 35's
02 GMC 2500HD 4x4 Duramax
Old 01-01-2019, 10:33 PM   #5
AussieinNC
Moderator
AussieinNC's Avatar
The lifter has most likely either collapsed or has junk in its sealing valve...or, the lobe has died and lost its lift ramp....
Either way, flat lifter cam or roller lifter cam, its to to pull the manifold and distributor...and remove the offending lifter...
Roller cam...if the roller on the bottom of the lifter is intact, the internals of the lifter is faulty and the lifter needs replaced. If the roller is locked up or missing...you will have to pull the cam and replace all lifters and the cam.
Flat lifter cam...remove the lifter and inspect the bottom surface,,,,it is most likely tore up...if it is...time for new cam and lifters...if the bottom is still ok, the internal valve has collapsed ...replace the lifter if the cam lobe looks ok...
Family and country before all others...
2006 Chevy Silverado (Daily Driver)
2025 Chevy Equinox
AussieinNC is offline   Reply With Quote
Old 01-01-2019, 11:11 PM   #6
toolboxchev
If you adjust all the noise out and it returns in a short period (2 to 4 weeks) I would suspect the same.
Fuel mileage will absolutely go less that 6 mpg also. Even with these things I would still have movement on all the rockers when running. Certain valves on this engine were sunk over 3/16ths of an inch when the heads were pulled. Its hard to diagnose with even a compression test, use your best measurements and trust your gut.
It may be something else collapsing like a pushrod.
toolboxchev is offline   Reply With Quote
Old 01-02-2019, 08:35 AM   #7
Myoldtruck
Myoldtruck's Avatar
Aflter you made the adjustments to that one, could you see any movement of it while the engine was running. Only other way to confirm I would confirm the lobe is ok is to set up a magnetic dial indicator above that rocker and spin the motor by hand to measure the lobe somewhat.
Im about to run marvel oil in with my regular oil to help with lifters on the 71 gmc i just bought. before i make any adjustments. Hoping this will wake up any stuck lifters first.
Myoldtruck is offline   Reply With Quote
Old 01-02-2019, 09:05 AM   #8
toolboxchev
I would try this before Marvel Mystery Oil, Lord only knows whats in that stuff today as the EPA can regulate them and force them to change compounds in it.
Its been going on for years.
https://www.amsoil.com/shop/by-produ...code=FLSHCN-EA
