Old 01-01-2019, 10:48 PM   #1
B. W.
B. W.'s Avatar
Dimmer Switch Screws
Does anyone know what size the pan head screws are that hold the dimmer switch? The PO broke the screws off then drilled them out, etc, etc. I want to go back with the original size hardware.
Also. on the backing plate are there nuts welded on or is it just tapped? Thanks.
B. W. is offline   Reply With Quote
Old 01-01-2019, 11:36 PM   #2
71CHEVYSHORTBED402
71CHEVYSHORTBED402's Avatar
Re: Dimmer Switch Screws
Mounts using two #3 phillips panhead screws with integrated star washers. The screw threads are 1/4-20 x 7/16.
The RH screw mounts a rubber-coated J-clip wire retainer. This retains the wires routed to the rear cab, for the dome and fuel tank sender.
The backing plate itself is tapped, and the plate is welded on.
Tony
71 Custom Deluxe, SWB, 2WD, 402, A/C. I developed an assembly kit for restoring the (a) truck from the ground up. My build thread, and more on the assembly kit https://67-72chevytrucks.com/vboard/...d.php?t=730025
71CHEVYSHORTBED402 is offline   Reply With Quote
Old 01-02-2019, 11:49 AM   #3
B. W.
B. W.'s Avatar
Thank you, that's exactly what I needed! Great pic. My plate is all boogered up.
