WTB 4x4 shock mount bracket needed
Looking for a front left shock mount bracket for a '60-'62 4x4 (see pic). Please post or PM with any leads.
Re: WTB 4x4 shock mount bracket needed
Have seen that on a lot of 60-62 shock mounts like that, why not clean up that weld? Never understood the reason for the pin like that for shock
Yeah that's probably why they got rid of it in '63.. Like to find a clean one if I can.
![]() Join Date: Sep 2011
I could be wrong but that really looks like the upper from 55-59 Chevy Pickups. without measuring might be wrong but might be worth checking out.
Makes sense, this is 60-62 so could be carried over from 59.
I have one from a 55-59 . Have pics on my phone if you pm. $35. They are a mess to get off. Price reflects laying on back with torch. Thanks
Awesome, thanks Paul. Been there/done that with the torch and rivets, I appreciate it
PM on the way.
Sent pics of bracket to your phone. Will get off today and send you measurements . Thanks
'59-down turned out to be different, still looking. Bump
Ttt
Bump
Ttt
#13 |
Active Member
![]() Join Date: Mar 2019
#14 |
Thanks Dennis I'll be in touch
#15 |
Bump, still looking
#16 |
That's stamped steel, not cast, right?
Why not cut it back apart, through the weld, then re-weld it correctly, and reinforce/gusset it while your'e there? If you're going to remove it from the frame anyway, unless you're going to re-rivet it, it won't be "concours correct," so you could weld a half-round of tubing to the back of it, and we'd the ends of the tubing to the bottom side of the frame rail, and make it really strong. (I'll be doing that on my '62 K10 frame...)
'61 Suburban daily driver: off the road due to 180-pound 8-pt buck! '62 K-10 long-step project '61 C30 Camper, aka "Valdez" There's no cool like Old School |
| Bookmarks |
