01-02-2019, 09:31 AM | #1 |
C notch necessary for 3” drop?
Just wondering if this is something I need to do when using 3”
Drop rear coils on a 1960 c10? Some kits advertise it for 4” and lower but I wanted to know if I will run into issues at 3”. Thanks Posted via Mobile Device |
01-02-2019, 10:17 AM | #2 |
Re: C notch necessary for 3” drop?
Well, just for reference......I just installed a 5" spring and a 1" block in the rear of my 64. The rear axle will hit the frame only on big dips. I'd say in the 200 miles that I've put on the truck with this set up, it has hit the frame maybe 4 or 5 times. So, I think I'll go ahead and put in a small bolt in c-notch. Previous to this set up, my truck had a 3" spring and it made no contact at all. Note: I don't haul anything of significant weight.
01-02-2019, 12:59 PM | #3 |
I have a 2 inch drop spring and a 1 inch block. No frame mods and zero problems.
01-02-2019, 05:10 PM | #4 |
Ok thanks guys, I will try it as is and see how it goes.
01-03-2019, 11:28 AM | #5 |
No c notch required with 3" drop
1965 C10 LS2/4l70, WHITE, 5/7 DROP LINK TO SUPER SNOOPY C10 BUILD---> http://67-72chevytrucks.com/vboard/s...d.php?t=689283 1977 C10 SILVERADO HAWAIIAN BLUE, 5/5" DROP, LS6/4L80E 1976 CHEVY K5, 350/350, YUBA GOLD/SADDLE |
