Old 01-02-2019, 01:14 PM   #1
Noah96
Light problem
Almost have all my kinks worked out but when I’m driving at dark and go to kick on my highbeams my dash lights go out but if I keep them on low beam the lights will stay on. Any idea what is causing this?
Noah96 is offline   Reply With Quote
Old 01-02-2019, 02:27 PM   #2
notsolo
notsolo's Avatar
Re: Light problem
Check your ground wires 1st, then double check. Dash should have a ground wire clip, and a couple built into the harness.
notsolo is offline   Reply With Quote
Old 01-02-2019, 09:54 PM   #3
Sheepdip
Sheepdip's Avatar
Re: Light problem
90% of electrical gremlins are grounding problems.
Sheepdip is offline   Reply With Quote
Old 01-04-2019, 11:57 PM   #4
Wrenchbender Ret
Re: Light problem
Check the plug at the dimmer switch. These are nortorious for getting corroded or the switch is bad.
Wrenchbender Ret is offline   Reply With Quote
Old 01-05-2019, 10:35 PM   #5
rjs53
Re: Light problem
X2! Just replace my dimmer. Chased wiring and eventually checked the dimmer. It was full of corrosion. $12 bucks at NAPA and problem solved.
2003 Dodge 2500
1969 C10
2014 Camaro SS/RS/1LE
rjs53 is offline   Reply With Quote
