01-03-2019, 09:52 AM | #1 |
Shift Linkage
I tried searching and it came up with a very wide variety of results but couldn’t quite find the answer for my case. I have a 66 C20 that I’m putting a 454 in with a turbo 400 backed up behind it. I also have an aftermarket tilt steering column that is shifted on the column. I’m looking for information on what to do about a shift linkage from the shifter on the column down to the trans. Any help would be greatly appreciated.
01-03-2019, 11:17 AM | #2 |
Moderator
Re: Shift Linkage
Google for a Column Shift Linkage Kit. You will want to measure the distance between the column shift arm at the end of the column to the transmission shift arm on the trans. Then shop for the best product.
https://shiftworks.com/collections/c...sal-column-kit You can then read in the FAQ section threads on Steering Column installs - http://67-72chevytrucks.com/vboard/s...d.php?t=646002
01-03-2019, 01:55 PM | #3 |
Re: Shift Linkage
Somebody has a cable setup for a column shift. Maybe Lokar?
1961 chevy K10 my build is------------61K10 build |
01-03-2019, 02:31 PM | #4 |
Re: Shift Linkage
Take the linkage and the lower bracket off of a 73-87 chevy truck. I have a 65 with a 454 and a 700r4 and it works good.
01-03-2019, 08:56 PM | #5 | |
Re: Shift Linkage
Chris |
01-04-2019, 01:35 AM | #6 |
60-66 Nut
Re: Shift Linkage
On my '66 Suburban with a 454 and TH400, I fabricated my own linkage similar to the Shiftworks item linked by Rocknrod. In over 120,000 miles I have never had any issues with it.
01-04-2019, 03:08 AM | #7 | ||||
Re: Shift Linkage
Yeah Lokar was what came up on my initial search, I was just looking for other options to consider. |
01-04-2019, 08:58 PM | #8 |
Re: Shift Linkage
If you need the linkage from a 73-87 I have everything to get you fix up $25.00 plus shipping
