Old 01-03-2019, 03:56 PM   #1
lks dcvn
lks dcvn's Avatar
Power Steering - ATF or Power Steering Fluid?
Bought a project 70 2wd Blazer - Power steering reservoir was empty - I'm sure it has a leak somewhere - unsure of hose/seal just yet and will need to fill it up to find out where it is coming from or if I just got lucky and it was drained.
I've heard use ATF and I've heard use Power Steering fluid.
Which is the best/correct choice here?
lks dcvn is offline   Reply With Quote
Old 01-03-2019, 04:02 PM   #2
MySons68C20
MySons68C20's Avatar
Re: Power Steering - ATF or Power Steering Fluid?
ATF / Dexron III is what I use. I have a reman box from Redhead and what they said to use.
Blake
MySons68C20 is offline   Reply With Quote
Old 01-03-2019, 06:32 PM   #3
68Stepbed
68Stepbed's Avatar
Atf
Matt
68 C10 stepside, LS1/700R4, TCI Engineering suspension system
68Stepbed is offline   Reply With Quote
Old 01-03-2019, 06:57 PM   #4
truckster
truckster's Avatar
I've been using Dexron ATF in all my vehicles' power steering for the last 40+ years.
I have sworn upon the altar of God, eternal hostility against every form of tyranny over the mind of man. - Thomas Jefferson
1972 K/5 Blazer CST 4WD
1963 Corvair Monza Spyder Turbo convertible
1995 Camaro Z/28
truckster is online now   Reply With Quote
Old 01-04-2019, 08:58 AM   #5
lks dcvn
lks dcvn's Avatar
Thanks all!
Old 01-04-2019, 11:35 AM   #6
GASoline71
"I ain't nobody, dork."
GASoline71's Avatar
I'm the odd man out and just use power steering fluid. LOL!
But if you're looking for a leak in the P/S system, it'll be easier to see the red dye of ATF.
Gary
'cuz chicks dig scars...
My 1972 GMC 1500 Super Custom (Creeping Death) "long term" build thread.
The Rebuild of Creeping Death after the wreck
Originally Posted by LONGHAIR View Post
I would never rebuild a 305.
Originally Posted by prostreetC-10 View Post
I love using vacuum gauges as part of the carb tuning process. I hook the gauge to the inside of my garbage can and leave it there.
Originally Posted by Marv D View Post
Remember Murphys 2nd law of mechanical relationships... "OPPOSING COMPONENTS ATTEMPTING TO OCCUPY THE SAME SPACE, AT THE SAME TIME, GENERALLY END UP OCCUPYING ADJOINING SPACE AT THE BOTTOM OF THE OIL PAN"
Originally Posted by cableguy0 View Post
Its cheaper to listen to advice given when you ask for help than it is to ignore everyone and wait for carnage.
GASoline71 is offline   Reply With Quote
