![]() Join Date: Sep 2017
Bear claw install???
Ok, I got the large bear claw's installed in the 48 doors. It looks like this
IMG_2130 by Robert Moorman, on FlickrI'm still trying to figure out how to make that jamb plate look good or at least better. So while thinking about that I decided to try the new window channel with the installed Bear Claw latch. This picture shows the channel NOT sitting firmly against the outside edge of the door. IMG_2126 by Robert Moorman, on FlickrLooks like it is out about 3/8" IMG_2127 by Robert Moorman, on FlickrIt is hitting latch at the opening in the window channel IMG_2128 by Robert Moorman, on FlickrAt that rectangular hole. Is this a problem? If so, has anyone else had this problem and figured out a solution? I will call Trique Mfg tomorrow to discuss with them, maybe they have an idea of what to do.
8man-aka Robert 1948 on a S10 Frame, small block with a carb 1954 Cab, 53 Front and Bed, 50 Doors, S10 Frame, Power TBD Build thread: "]http://67-72chevytrucks.com/vboard/showthread.php?t=746899&highlight=wife%27s+48[/URL] [/URL]http://67-72chevytrucks.com/vboard/showthread.php?t=840204 |
Re: Bear claw install???
I installed Trique Mfg bear claws on my '52 with no problems.
Looks like '52 on up door handles, but you mentioned '48 doors. |
I believe your suppose to notch the window track in that area. on my 50 the instructions said to notch
1950 3100 5 window |
Thanks. I read the instructions and they said to "remove the hump" with a picture of where the "hump" is. The new repro channel has no hump to remove, so I'm still confused.
I have an email or 4 into Trique and I called this morning, but the boss wasn't in yet, so I'll call again after lunch.
#5 | |
Scott ______________ my '51 build: http://67-72chevytrucks.com/vboard/s...d.php?t=677979 |
where the nut is hitting the window channel can you not reverse the head and nut around?
An object in motion will stay in motion till you run out of gas |
1952, thanks for looking at the issue. That nut barely misses the channel, but I can get a different bolt with an Allen head and reverse it.
The real issue is at the rectangular slot, you can see the lever that goes from the push button into the latch. That is where the channel is hitting the latch. I've ordered the felts so I can install them and check the window to see what happens. I'm hopeful that it will work. If not, cutting a groove in the channel will be the next step.
| Bookmarks |
