Widest rear tire/wheel
Just wondering if anybody knows the widest rear wheel & tire combo that fits in the 60-62 stepside trucks? I have a 73-87 rearend in the truck and I believe they are just a little bit wider than the factory rear. Anybody have a certain combo under a truck like this? Thanks
Posted via Mobile Device |
1965 Chevy C10, 2005 4.8L/4l60
![]() Join Date: Aug 2004
Re: Widest rear tire/wheel
1.5” wider than stock to be exact. Have you tried to search for rear wheel width?
Different years but you will get the idea. http://67-72chevytrucks.com/vboard/s...ad.php?t=67082 http://67-72chevytrucks.com/vboard/s...d.php?t=430269
Clyde65 Rebuild of Clyde http://67-72chevytrucks.com/vboard/s...84#post8338184 69 Aristocrat Lo Liner build http://67-72chevytrucks.com/vboard/s...84#post7561684 ![]() ![]() ![]() support our troops! |
Thank you I will check them out. I’m hoping to squeeze 10” wide wheels in the back
60-66 Nut
![]() ![]() Join Date: Mar 2007
That's not going to happen with the wider differential and a stepside, especially of you are lowering the truck. Unless you have wheels made with a special backspacing and you add a small inner wheel well.
#5 | ||
But Found Her 25yrs Later!
![]() Join Date: Oct 2010
This may or may not be helpful :
I lost my 65 - Found it 25 years later: http://67-72chevytrucks.com/vboard/s...d.php?t=426650 66 C20 Service Truck: http://67-72chevytrucks.com/vboard/s...d.php?t=428035 |
btw... This is with the stock rearend - they stick out past the stepside fenders.
Here's a thread about rolling the inside edge of the fender:
http://67-72chevytrucks.com/vboard/s...ls#post8261780 . Here's a tire and wheel thread : http://67-72chevytrucks.com/vboard/s...ls#post7993326
