![]() Join Date: Mar 2011
shock hardware HELP
can’t seem to locate these ( I will call them studs not sure what they are called ) the shaft that the shock slides on to needs to be 1/2 anyone know where to buy ...I was on KYB site nothing Summit nothing ....Im probably not using the right search criteria .....I know I can make something work with grade 8s but looks $hitty these are the front shocks frame mount hardware or top of shock is I believe 9/16 bottom of shock is 1/2 diameter that then bolts to control arm thats the one I need pictured here with a 1/2 inch shank
Grand Theft Auto https://67-72chevytrucks.com/vboard/...d.php?t=855961 Doc & Kim build http://67-72chevytrucks.com/vboard/s...d.php?t=722288 I am from the desert http://67-72chevytrucks.com/vboard/s...d.php?t=650332 basket case build SOLD http://67-72chevytrucks.com/vboard/s...d.php?t=648557 Last edited by zicc1835; 01-03-2019 at 10:54 PM. Reason: MORE |
| Bookmarks |
