01-04-2019, 01:12 AM | #1 |
Center crossmember
Just got a cpp center crossmember for my truck. My truck only has a 5in drop. Cpp said it will work. Has anyone used this crossmember
1970 chevy short box c10 factory 402 big block with AC 2008 chevy silverado regular cab short bed lowered 1990 454ss 52,000 miles 5/6 drop |
01-04-2019, 11:08 PM | #2 |
Gone Fishing
Re: Center crossmember
I plan on running one on mine
68 Chevy Short Fleetside LSX Swap Under Way 3.73 posi 2.5/4 drop Frame of resto has been started 2022 Hyundai Tucson Limited 2019 Chevy Traverse Redline Edition Wifes Ride Build Thread http://67-72chevytrucks.com/vboard/s...=1#post3483616 |
01-04-2019, 11:25 PM | #3 |
I have one I my '67. 2.5/4" drop, no issues.
1967 C10 Step side 1970 AMX 390 1977 Datsun 280Z highly modified with '95 LT1 power |
01-05-2019, 11:45 AM | #4 |
I have 72 swb frame 4-6 drop Early Classic c-member basically the same design no issues
Doc & Kim build http://67-72chevytrucks.com/vboard/s...d.php?t=722288 I am from the desert http://67-72chevytrucks.com/vboard/s...d.php?t=650332 basket case build SOLD http://67-72chevytrucks.com/vboard/s...d.php?t=648557 |
01-05-2019, 11:09 PM | #5 |
I’m only asking because the mounts for The trailing arm are upside down for the pinion angle
01-06-2019, 12:04 AM | #6 |
i can show you the angle of mine ...i would assume if cpp says it will work and they are welded in place why wouldnt it work ? maybe someone who has used one will chime in
01-06-2019, 10:21 AM | #7 |
The theory is the repositioned mounts for the trailing arms make the pinion angle better on lowered trucks.
01-08-2019, 03:30 PM | #8 |
You said you have one. Have you had any problems with yours
01-08-2019, 05:41 PM | #9 |
Nope. One thing I learned during installation is do not put jack stands anywhere near the crossmember. They will deflect the frame enough to make it very difficult to slide crossmember out or get the new one to lineup with the mounting holes. Also unless you have the cab off getting the top rear rivets out is a *****.
01-12-2019, 09:08 PM | #10 | |
